fluid in rear end?
Discussion in 'Technical' started by tommyboy, Sep 26, 2005.
  1. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    hey guys i was wondering is there something in the rear end that i should check and see if its full or if i need to put something in there like gear oil or something its on a 77 mav i6
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    You need to put in gear oil. There is a plug on the hub where you check and put gear oil.
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Gear oil....80/90(85/90).....the check/fill plug is on the differential case....usually a 3/8" square (I use a 3/8 ratchet),oil level should be approx.1/4" below the fill plug......Hotrod-Daddy
  4. scooper77515
    And if you end up busting the 3rd member loose to drain that nasty old stuff out, be sure to drill and tap a 3/8" pipe thread plug in the bottom for later draining. I never figured out why Ford did not put in drain plugs, just a fill plug. It's a bit@# to change the fluid without a drain.
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I agree w/ Scooper also :)
  6. tommyboy
    tommyboy 77 mav
    1977 maverick
    what is a 3rd member
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    3rd member... AKA pumpkin, aka Chunk, etc its the part that bolts to to the front of the rearend housing. It holds your ring gear, pinion, etc, your driveshaft is bolted to this via a ujoint.
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I guess Ford figures the only reason you would drain the fluid if is there was a problem? Wonder what the original manual said about changing rear end oil ...
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    It's just the same-old B.S. that car makers do. The objective is to get the car out the door and make a dollar. Repair and maintainence is your problem. Take heater cores for example; everyone KNOWS that they wear out and either stop working or spring a leak. But is there an access panel for easy removal & replacment? Hell no. I have yet to see a car that has a simple access for the heater core. Sure, non-A/C Mavericks are not very difficult, but on A/C models, it's a nightmare, and that goes for GM and Chrysler vehicles too. Yep, they can put a shuttle in outter space, or a man on the moon, but can't build a car with a simple heater core access, or in this case, a simple drain plug on a differential...
  10. Craig Selvey
    I know that 1968 Galaxies and 1976 LTD wagons have an access door for the heater core. Very, very easy to change one. Don't even have to drain the coolant.
  11. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Subject line: "Fluid in rear end?"
    Stay away from Taco Bell.
    (sorry, back on topic please. I couldnt' resist)
  12. T.L.
    T.L. Banned
    Southern Colorado
    I had no idea. ALL cars should have that, regardless of make or model. And they should also have an adequate drain system so that if it leaks, it does not spill coolant on the carpet and destroy it...
