Food for thought
Discussion in 'Technical' started by nickmav70, Mar 5, 2009.
  1. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    ok we all know how a supercharger works... and we all know how a A/C compressor clutch works... why has noone combined the two to have a supercharger you can turn on and off?
    Just pickin your brain....
    :stirthepot:
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    My Eaton S/C is only in boost under engine load due to the bypass valve. I commute with it everyday on the highway and never go into boost ...
  3. maverick75
    why would you want to turn a supercharger off?
    You can limit the boost for highway then turn it all the way up for the track.
  4. nickmav70
    Dallas, GA
    1971 Ford Maverick
    im not saying i would want to but i know people driving force-fed cars for any extended period of time sometimes want to give it a break...
    i was thinking of something like a bypass also... inside the supercharger have a routing for the air so when the clutch releases it is like have an N/A car with just low compression... so you could take your supercharged street car on long road trips but get great gas mileage while doing it... HIGHWAY SPEEDS EAT UP GAS IN A FORCE-FED CAR
  5. maverick75
    mot necessarily i'm not a expert or anything on boosted applications. But i do know a couple of people who get better mileage after they added a turbo/SC
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Like in Mad Max :D
  7. nickmav70
    Dallas, GA
    1971 Ford Maverick
    it all depends on what your boost is set up for... for instance... you can take a buick 3.8 s/c and get like 35 miles to the gallon and on the other hand you can barely get 16 out of a ej20 subaru wrx... it all depends on if its power boost or just necessary boost
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    yea. . . that's it, we ALL know how a supercharger works! But... let's say for the sake of arguement, all those guys out there who don't know, how does a supercharger work? :rolleyes: Because I want to help educate the others . . .
  9. nickmav70
    Dallas, GA
    1971 Ford Maverick
    im talkin about a roots style so....
    belt driven pulley connected to a shaft that spins two corkscrew style turbines (in opposite directions) to pressurize air into and intake
  10. maverick75
    i get you:thumbs2: i've been hanging out with a couple of the SVO 2.3 guys they get 30MPGs and run low 12's...its not fair:D
  11. nickmav70
    Dallas, GA
    1971 Ford Maverick
    :rofl2:yep sure isnt
  12. dmhines
    Cumming, GA
    A Roots style is ON or OFF ....
    OFF when there is engine vacuum ... ON when there is no vacuum - i.e. load or WOT. This is all thanks to the vacuum controlled relief valve.
    My car idles at 20HG ... and hits 10PSI boost at around 5000 RPM.
    The M90 on my car draws about 1/3 HP from the engine when no boost ... and up to 40HP from engine under full boost at 5200 RPM .. that is why turbo's are so much more efficient.
    I could easily drive from GA to CA and never hit boost ... so the complications of adding an electric controlled clutch probably isn't worth it.
  13. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Ok. Enough tech talk.....
    Give your son the video camera and let's see that V6S in a burnout on Youtube! :thumbs2:
  14. nickmav70
    Dallas, GA
    1971 Ford Maverick
    thanks for the info guys :thumbs2:
  15. dmhines
    Cumming, GA
    Here is one youtube of when I first got it installed .... Intercooler is due out in a couple of months to upgrade the RWHP and TQ 40 each ...
