found a rear differential locker, anyone using it?
Discussion in 'Technical' started by mean_maverick, Nov 11, 2009.
  1. mean_maverick
  2. maverick75
    WoW! that is a great price...never seen them under $400
  3. mean_maverick
    "limited slip" units are on there all day for $325... :huh:
  4. maverick75
    I never go to ebay anymore.... ive seen the richmond powertrax for $477 and the Auburn lsd for $476...i guess i should start shopping on ebay again.
  5. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Pretty cheap and popular way (assuming that isn't a knock off) to lock the rear end. Have one on my Ranger's 8.8 rear end. Gives me great traction off road and a little more than I'd like on the pavement. Sharp turns and corners cause it to lock and I can hear the tires chewing up the road. Tire wear I imagine is accelerated. Also, the manual transmission shifts are jerky if I don't match the revs just right... Near about have to drive it like an unsyncro'd tranny to shift smoothly (a non issue if you have an auto trans).
    All in all it's worth it to me. About the cheapest way to lay out even power to the ground.
    Also, Ive heard rumors of failure in either high power or big tire/off road situations. Might be something to research... Especially if you take your car to the track.
  6. yellow75
    Tillamook Oregon
    I had a Detroit Soft locker in my last car, very similar to this unit. I really liked it with the exception of the fact that it had a little play in it, it would move about 6 inches before gears locked up, install instructions stated that it would. No special additives needed just some good ol 90 weight
    It always locked up but at the strip you had to keep the rpms up and keep pressure to it or you would have that 6 inches of free play before it took off. Was not nearly as clunky as a true Detroit locker in the noise department. I would buy another one
  7. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    I picked one up on ebay a couple years ago for $175 shipped ...NIB:dance:
  8. 71gold
    I've had one in my Mav. for about 4 yrs.
    street tires/slicks...no noise or chewing...
    ...:thumbs2:...
  9. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Then you ain't driving 'er hard enough :rofl2:
  10. olskool
    olskool Member
    tulsa oklahoma
    1975 more door
    i have put them in few cars no problems if its the true richmond gear brand then its all good they make great stuff
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    $294.95 at Summit there is another model that sells for $494.95
  12. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    i love em.my wife installed it in about an hour and she's never worked on a rear axle before.put in a new pin in if yours is worn.after i blew up the first one when she put in the second i shimmed the springs about an 1/8th inch to put a little more preload on it.watch the throttle on turns until you get used to it.
  13. Bryant
    the one pictured is the 495.95 one. the 294.95 one only replaces the spider gears and uses the stock side gears.
  14. mean_maverick
    so this is the type of posi in your car? if so, that's good news. im going to try to pick one up after the holidays are overwith. ill get the kid's christmas over with and then get daddy something for himself :D
  15. Bryant
    this is a locker, not a posi. they function differently. the locker literaly locks the axles togther when power is applyed. the posi has pressure applyed between the side gears and the case to give a resistance to the spider/side gears so the power flow wont just travle the path of lease resistance.
