Frame stands
Discussion in 'Technical' started by MATTBLACK, Aug 29, 2013.
  1. MATTBLACK
    MATTBLACK Member
    Abbotsford B.C. Canada
    I have looked through a bunch of the existing threads on frame stands for the 289/302 conversion and I have a few questions. Someone here said that crites has them for 99 bucks. I went to their site and under frame mounts for maverick it lists "N/A". I know AutoKrafters has them but at 199 a set its a bit too much for me. Did Crites stop making them? I also saw the "joe dirt" mounts on here where 250 frame stands were used swapped side to side and late 70's f-100 mounts were used. Would 200 frame stands work with that system as well? And if so, does that system affect the fitment of the oil pan and headers?
  2. rthomas771
    200 and 250 frame mounts are two different animals. I remember reading the 60-65 V8 Falcon 3-piece mounts will work with a Maverick V8 swap. These parts can be bought through most Falcon vendors. You will need to drill the third hole in the shock tower
