from a 200 to a 302...
Discussion in 'Parts Interchange' started by KISSarmy, Feb 23, 2015.
  1. KISSarmy
    KISSarmy Member
    California
    Is it tough to put a 302 in a 1971 Maverick?
    I know a new rear end has to go in, but...is that the extent of it? I can do a little of the work, but changing the engine out is out of my league.
    Already has a C4.
  2. bmcdaniel
    If you do a search there's a couple threads on here that details what needs done. But yes, a 302 bolts right in with the proper mounts. You'll need a bigger radiator and if you have the small brakes you'll want to upgrade them.
  3. 71gold
    if you have a 200 you will need a least a 250-302 bellhousing.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You need bigger brakes regardless of what size engine.
    There's a Tech article on here somewhere on how to do the swap.
