front brake hose questions.
Discussion in 'Parts Interchange' started by Joe Dirt, May 3, 2009.
  1. Joe Dirt
    Ok guys ive rebuilt the whole drum setup on the front of my car down to the hoses and now i picked up a disc brake swap at a deal and was wondering if it is possible to reuse my drum brake hoses on them?
  2. Jamie Miles
    I've never tried it, but if they will screw into the calipers, I don't see any reason why you couldn't modify the steel lines to make it work, unless they aren't long enough.
  3. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Wheel cylinder is located different ( at least mine were) and the brake hoses are just a tad short. They fit, but I wouldn't want to drive it that way. Since car is not drivable I have left them on for now but will be either replacing hoses or more likely hard lines before driving.
  4. rthomas771
    When I swapped to disc brakes the rubber hose that came on the caliper did not fit my steel line, the hose was too big. I bought adapter fittings at Napa. I don't recall if they were different length.
  5. GRAPESODAMAV70
    GRAPESODAMAV70 New Member
    Texas
    1970 Ford Maverick
    OK GUYS, I got one for you. I swapped 4-lug drums for 5-lug drums, because I could not find factory rims that were worth buying. Not only that, my drivers side flex hose was broken in two when I got the car. I could not get one nowhere. So, I got the front spindles and drums off a 73 4-door. I bought new flexlines for them, but they were not long enough, so I bought longer ones. That helped me alot, but now I have a new problem, the new lines won't screw into the steel brake lines. What could I do to solve this problem? Stumped In Texas.
  6. Jamie Miles
    Get brass adapter fittings.
  7. Joe Dirt
    maybe relocate the metal line short or no way short?
  8. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    well I still have full turning radius but when I turn to limit the hoses are at a stretch.
    I don't know if I could just relocate metal lines as my car had sat for 20+ years in a yard and the lines are pretty rusty and I will need to replace them anyway. I never determined if I could have made the original metal lines work. From memory I would have liked about 3" more hose to feel I wasn't putting stress on them by making hard turns.
  9. Joe Dirt
    ok,that helps me put it into perspective(y)
  10. ATK
    ATK Member
    D/FW
    Both
    After years of scrounging for Granada disc and scouring yards from dead Mavericks/Comets to perform brake swaps on other peoples rides, I'm planning on doing this to both my cars:
    http://www.mustangsteve.com/cobrabrakes.html
    Seems a no-brainer to use commonly available brake components - cheaper too
  11. Dave B
    I used 74 disc brake hoses when I converted the drums to disc's on my 73 with no issues at all, I even left the steel lines in the place that the factory bolted them to.
  12. dtb147
    dtb147 Member
    Arbutus, MD
    This is what I did as well. The 74 hoses fit my 71 steel lines, but had the proper end to fit the calipers. I had to rebend the steel line to the proper direction/location however.
  13. Joe Dirt
    well the drum hoses are long enough but the fitting where it screws in is 3/16 insted of 1/4 like the caliper.I ended up getting some disc brake hoses but then the metal line end was too big so i went to o reilly's and picked up 2 edelman 258340's line adapters 3/16 to 1/4 so i could use the disc hoses with my drum steel lines
  14. ATK
    ATK Member
    D/FW
    Both
    The above should be a sticky! (y)
