Front coil spring question
Discussion in 'Technical' started by fixmer, Nov 27, 2004.
  1. fixmer
    fixmer Member
    I have been accumulating all new front suspension parts for my 71 Mav, but I'm not sure what springs to get. I'll have an aluminum intake and heads on a 302, a three row "stock" size radiator, and no A/C. I know lowering is in style, but I like the raised up look...just a hair lower in the front than the attached photo.
    I want the radius of the wheel opening to be on about the same center as a 15" (225/60/15) tire. I know this isn't the look that a lot of people are going for, but I was hoping for some input on a specific spring and where to buy it.
    I know the handling will suffer, but I like the look enough to deal with it. I was just looking for someone with a similar setup to mine that got the results I'm looking for using an off the shelf spring.
    Thanks
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Unfortunately, its really a "trial-&-error" thing. I'd start with a new set of 550 pound V-8 coil springs. That might give you what you're after...
  3. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I would think that the 550 lb spring might lower it a little. T.L. did it lower the car a bit? If so maybe 1 or 1.5 inches. With the lighter front end weight, maybe the car would come back up just a bit. I'm just thinking. I order my springs already lowerd. I'm not to happy with then. I order them 2 inches lower. I'm thinking about a mustang spring 550 lb or 600 lb.
  4. T.L.
    T.L. Banned
    Southern Colorado
    I'm talking about stock-height V-8 springs, not lowering springs....
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I'm sorry. I didn't know 550 lb was a stock spring. I thought 550 lb was an aftermarket performance spring.
  6. fixmer
    fixmer Member
    Thanks for the info
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Just buy a V8 spring and cut it down until it is the height you like ....
  8. strokermotor
    strokermotor STROKER MOTOR
    CHICAGO,ILL
    75 MAV, 48 FORD COUPE,86 F350 CREW CAB 4X4,05 FOCUS
    springs
    Hello, i want the springs you take out if they are the ones in the picture , I LIKE IT THAT WAY !!!!!!!!!!!!!!! let me know!!!! stroker
  9. dmhines
    Cumming, GA
    I just noticed your pic ... seems like the springs you have now should work ... you should be able to just cut them down til your happy ...
  10. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Here's a picture of my Maverick that's raised just a little bit. Is this the "raised up" look you are looking for?
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    aaaaaah :confused:
    thats not a maverick.....is it:slap:
  12. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    definitely a trial and error......if you start cutting, make sure when you get done that you take it to a shop and get the front end aligned.
    here is mine with 2 rounds off 6 banger springs....it is really to low for a daily driver, puts the tranny pan a little low to the ground....but I like it:D
  13. HeLMeT 76x2
    HeLMeT 76x2 Two 76 Fords...!!!
    Vancouver, wa
    1 1976 ford 4-door maverick. 1 1976 ford econoline 100.
    i sure hope that's not a maverick.... looks like a pint-0-beans
  14. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    Maybe its just had a little body work....Erick, is that how all your other Mavericks look? :16suspect They just might not all be Mavericks...just a guess ;)
  15. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    I used 620 springs for performance ,but as an option ,you can get spring spacers that go on top of spring to raise it up a bit. I would not raise it more than an inch to inch and a half over stock tho. JMO
