front drum
Discussion in 'Parts Interchange' started by magecmike, May 21, 2013.
  1. magecmike
    magecmike New Member
    toledo ohio
    1962 comet
    Had to get new frt drum on my 62 comet. took it to a shop and they pressed the bearings in the hub. however they ground down the studs a little to get old drum off. ( thought this was to be machine pressed. thats why it went to shop)now the new drum is not tight and snug. more like a back drum. is this ok? if not how do i correct this? new studs? any help appreciated. thanx, mike
  2. magecmike
    toledo ohio
    1962 comet
    Figured it out. as long as drum stays tight to center hub all is well it can float like a rear drum. Thanx
  3. 71gold
    glad it worked out for you...:thumbs2:
