front end clunk
Discussion in 'Technical' started by wakywaco, Sep 7, 2004.
  1. wakywaco
    wakywaco Member
    waco
    1975 v8 maverick
    My maverick has just started making a clunking nise on the drivers side wheel. The car seems to pull to the drivers side also. Could something be causing the noise and the pulling also. It doesnt always pull. Ive checked my brakes and all seems fine there. Looking under the car I dont notice anything. What are the symptoms I should be looking for. Coil spring mounts, ball joints etc.
    thanks guys
    Steve
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Check your ball joints and also your strut rod bushings. My strut rod bushings failed and started making a big clunking when I would go from forward to reverse, and vise versa.
    -Corbin
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    When I tore mine apart, it had squeaked and banged for years.
    The upper control arm bushings on the back were not where they
    could be greased. It had gotten so dry that it rubbed a hole in
    the contol arm bolt. That holds the bushings in against the control
    arm.
    Seth
  4. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Usually those uppers control arm bushings squeek long before they clunk. My money is on the strut rod bushings.....
  5. wakywaco
    wakywaco Member
    waco
    1975 v8 maverick
    The clunking noise happens when I hit bumps, even small ones. Does someone sell a complete front end kit. My car has low mileage but what the hell. I wouldnt mind replacing everything.
