Front End Help
Discussion in 'Technical' started by Scotty P, Apr 20, 2006.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Ok, I am finaly installing the front end rebuild kit I bought a year ago! I am having the car painted next week, so the pressire is on to get it done. After removing the spring last night I started on the upper ball joint. My faher had changed this to a bolt-in in 1975 so I thought I was home free. Well, I removed the three bolts holding in on and it won't budge! Do I drive the joint upwards to remove? It has a threaded stud that points down towards the spindle, that is not bolted in is it? :huh: Am I making any sense here? The front end is not my area of expertise.. Thanks for the help.. Scott
  2. Mavaholic
    Once you remove the 3 bolts, one on each side of the hump where the grease fitting comes out, and one behind it, the whole ball joint should just drop right out of the bottom of the A frame. I have never seen one stick but if it is, you should be able to take a punch and drive it down and out by going through the cutout (hole) where the grease fitting is.
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    The "bottom" of the A frame? need to re-look tonight when I get home. I also removed the nut on the botton of the joint, did not help. The rubber cups (lack of a better word) sit on TOP of the A frame. The go down through the hole?
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You did separate the balljoint from the spindle??
  5. mercgt73
    mercgt73 Member
    Yes, did you remove the cotter pin and castle nut from the ball joint, and use a splitter or BFH to seperate the spindle from the ball joint stud?
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    removed the 3 bolts on top, removed the castle nut on bottom. Did not use the BFH! I guess I thought when I unbolted the ball joint it would fall out! NAIVE! Give me a cylinder head to port and I would be happier!!
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    merc, tell me more. The upper arm is out, the ball joint is on top of the spindle. Now what? Can I do this w/o the tool? I do have the BFH
  8. maverick1970
    Missouri
  9. Scotty P
    Scotty P Member
    santa rosa, ca
    I have it, drove it all the way in and no luck!
  10. Scotty P
    Scotty P Member
    santa rosa, ca
    the balljoint looks like a trailer hitch yes? With the bal on top and a stud that goes through the hole in the spindle? I have it all apart and yet can not get the stud to come out of the top of the hole in the spindle, it is not threaded is it ?
  11. maverick1970
    Missouri
  12. Scotty P
    Scotty P Member
    santa rosa, ca
    hee hee NOW YOU TELL ME!! Kidding.. hammering away here..
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    got it.. gee that was fun..
  14. maverick1970
    Missouri
    You won't make that mistake again!
  15. Scotty P
    Scotty P Member
    santa rosa, ca
    dunno about that! There is still the other side to do!!
