front end rebuild
Discussion in 'Technical' started by billt, Feb 28, 2008.
  1. billt
    billt Member
    Colorado Rockies
    74, V8, auto, orange
    kind of a newbie question but need advice. I recently got a 74 V8, auto, power steering. The upper inner bushings are badly worn as is the ball-stud at the control valve.
    Just got my handy dandy 5 volume set of 74 FORD factory manuals from Faxon, and it looks like a major front-end job requires some special tools and some precise measurements
    Not sure I should tackle it myself, maybe take it to a shop??? (those top-mount springs are a bit scary)
    Anyone with experience, advice, suggestions?
    Thanks,
    Bill
  2. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    Use a proper spring compressor. Be carefull and safe, they can be deadly when someone is stupid about it. Fords of all types ran a similar spring setup and many here have safely delt with removing them.
  3. Dave B
    What I found was that not all spring compressors will work, it's a pretty tight fit. I'll see if I have a picture of the one I had to buy, or there might be one on here somewhere (try a quick search) The upper control arm bushings are easy to change, but you may find that the threads may be stripped and then the arm needs to be replaced.It's all pretty simple, you'll need an alignment after anyways.
  4. 71gold
    this is a loaner from...Auto Zone...
    ...frank...
  5. don graham
    When i did my front end I took measurements with a ruler. This got everything back in the ballpark.:)
  6. Jamie Miles
    When I rebuilt my front end, I literally just eyeballed the alignment. It drove like crap, but it was good enough to get it a few miles down the road to a shop to have the alignment done right. You can buy brand new upper and lower control arms with new ball joints and everything from most of the Mustang places, just get them for a '68-'73 Mustang. Can't see why anyone would mess with trying to rebuild the old ones when brand new ones are so cheap.
  7. billt
    billt Member
    Colorado Rockies
    front suspension rebuild
    Thanks for all the replies. My spring compressor is the wrong type, so will buy/borrow a good one. Also like the idea of a whole upper arm.
    This car's gettin' to be fun. Bought from a friend who had messed a little and gave up. Back when, I bought a brand new 66 Mustang. This car feels a lot like it... good memories.
    Thanks again,
    Bill
  8. MercFan
    MercFan Member
    Charleston, SC
    None right now, ('69 Cougar)
    BFH & a Spring compressor and go to it!
    Jamie mentioned that the mustang front end parts are the same. I bought all new front end part as a kit from Mustangs Plus and installed it on my Cougar (same layout). Their Grab-a-Trak brand is awesome, and gives a lot of bang for the buck. Try to plan out everything you need in advance, because you get a better deal the bigger the kit is. I found myself wishing I had included more in my initial purchase. I used a loaner spring compressor from Autoztoned. It was scary, but doable.
    As far as other tools go, an article by Mustangs Plus told me about the only other main tool I would need to disassemble the front end-- a BFH. As in big effin' hammer (y). Never use a fork on a FoMoCo product. But if you hit the ball joints in the 'sweet spot', things come apart nicely!
  9. Jamie Miles
    You mean a tie rod/ball joint separating fork? Why not?
  10. MercFan
    MercFan Member
    Charleston, SC
    Silly rabbit, forks are for chebbies.
    The pickle forks are intended for GM cars, not Fords. The fork will just serve to damage things. I was a little skeptical about the whole 'whack it with a BFH' technique, but it works!!! The only reason I had some problems was because I needed to hit it harder! Its fun.
    Here, check out the article that I used. It was awesome, and the only source I needed when completely dismantling my front end.
    This is page 2 (with the pics) of a 2-page article:
    http://www.mustangsplus.com/tech/shockandfall/shockfall2.htm
  11. PaulS
    I have several different thickness and sizes of "pickle forks" and I have never used them on a Ford yet. I have used a pitman arm puller but never the fork on ball joints.
  12. Jamie Miles
    Think I'll stick with my pickle fork. Don't much like the thought of beating the f^#k out of the front suspension on my car.
  13. Dave B
    When I went to trade school, the instructor was an old time suspension guy, thats what he always told us to do, a couple of good wacks with the ball peen, and they'd pop off.I tried the pickle forks last year on my Grabber, ripped the crap out of the boots.
  14. mavmike72
    mavmike72 Member
    louisville kentucky
    i took my front end apart last week end and thats what i did beet the f--k out of it didnt really like that idea but thats what i was always told.
  15. 69.5mav
    69.5mav Member
    Oregon
    What's a pickle fork????? I do brakes and suspension for a living on every type of car there is and I never use one. 1 or 2 whacks in the right spot and BAM!!! she's apart.
