Front end springs
Discussion in 'General Maverick/Comet' started by MKmaverick72, Jul 25, 2003.
  1. MKmaverick72
    MKmaverick72 Member
    Oregon
    1972 Grabber 302 A/T
    Has anyone cut the front springs to lower the front end or do you know a place that sells maverick coil springs that will lower the front end about 1 inch? Will this affect alignment or cause any problems?
  2. Old Guy
    Old Guy Member
    Springs
    Have done many cars this way. Use an air or electric tool with a cut off wheel, not a torch. About one to one and a half coils. Take it to a shop and get it realigned for sure. Watch out for bumps in the road and have fun with it.
  3. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Like Oldguy said, never use a torch on a spring. I cut 1 coil out of mine and it went from being slightly raised in the front end to level or a slight rake in the front.
  4. bmcdaniel
    If you have a 302 you can install 6 cylinder springs, works out about the same.
  5. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Or you could buy aftermarket Mustang springs for less than 100 and it will actually handle better too!!!
  6. AdsMav
    AdsMav Member
    Ontario Canada
    1976 Maverick
    What year Mustang? I didn't know Mustang springs fit?
  7. bmcdaniel
    '65 - '66 Mustang.
  8. j miller
    Polson, Mt
    my brother and i put the 6cyl springs in his 76 maverick after a 302 install and it lowered the front end approximately 1-1 1/2 inch with no noticeable change in the handling. hope this helps:cool:
  9. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Ok, I have got a question. How much will the front end lower when i put in the 302 if i keep the 200 springs?
    -Todd:)
  10. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Pic for Todd
    Todd, this is with a 302 that went into an original 200 car. I haven't changed anything in the front. This gives you an idea anyhow. Country
  11. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Looks like Im headed to a junkyard. It'll look funny with my new leaf springs with the two inch lift! Thanks. That clears it up pretty well.
    -Todd:)
