Front rollbar supports
Discussion in 'Technical' started by Beerstoreguy, Jun 17, 2007.
  1. Beerstoreguy
    Beerstoreguy Member
    St.Petersburg Florida
    1973 Comet
    My floors were so rusty I needed to put in these supports for the rollcage door bars.They really help strenthen every thing up.
    For the main hoop I cut out the sheet metal above the front leaf spring support(whatever it's called) and plug welded the base plate to it as well as all the way arround.And the sheet metal for the floor was free, it was an old AC air handeler box. I will prime and paint everything before welding in the floors, this won't be a show car so with carpet and padding on top who will know? This is my hot rod, "rice grinder" street machine project.
    Tell me what you think?
  2. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Just a thought, but if you tie those front bars to the subframe connectors, it will stiffen it up more.
  3. Beerstoreguy
    Beerstoreguy Member
    1973 Comet
    Yes they are welded to the front subframe top and bottom
  4. Beerstoreguy
    Beerstoreguy Member
    1973 Comet
    The supports are 3/16 thick and welded to the front subframe where they cross.
  5. mav1970
    If you have any room to add any gussets, now would be the right time to do it. A & A Manufacturing has some really neat die stamped gussets with 3 lightning holes in them. This will add strength.
  6. mcknight77
    mcknight77 Member
    Boise, ID
    My bad, I didn't look close enough! :huh:
  7. Beerstoreguy
    Beerstoreguy Member
    1973 Comet
    Yes mav70 I do have a bag of gussets I got from Jega when I bought the rollcage, thanks.
