fuel cell with low rear end outlets. Suggestions for install?
Discussion in 'Technical' started by scooper77515, Feb 12, 2010.
  1. scooper77515
    My fuel cell has a "ramp" angling down at the back where the two fittings are for the fuel to flow out.
    Has anyone used one like this and if so, how did you mount it?
    I could cut a hole in the trunk and let it sit below the trunk, but I was hoping to use the round hole in the floor where the fuel filler tube goes down for all my hoses and wires to drop down outside the car. Therefore, I would want to keep the entire cell in the trunk, and replumb and rewire everything to exit out that one big hole.
    Basically, I have a couple days (weeks, if the weather continues to refuse to cooperate) to figure out how I want to do this before I drain all fuel and remove the tank. So any suggestions will just get my little brain a-spinning until I get down on it and actually do the installation.
  2. Mavman72
    Thats the sump on the tank...You want it facing the rear of the car.
  3. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    Only way I can think of is to fab up a platform for the trunk floor. Raised around the perimeter with room for the sump to sit inside, resting on or slightly above the trunk floor.
  4. scooper77515
    Yeah, that was what I was thinking...set the tank higher than the floor, and let it sump down to the pump, etc.
