Fuel Gauge and turning Signals
Discussion in 'Technical' started by 1971 Mercury GT, Nov 3, 2008.
  1. 1971 Mercury GT
    1971 Mercury GT 1971 Mercury Comet
    Rancho Cucamonga, Ca
    1971 Mercury Comet
    For some reason when I use my turning signals my hazards come on in the back. The front turning signals are fine. I changed all my fuses and even replaced the flashers. Any clue?
    Also my fuel gauge does not work. I checked the connection at the tank and traced it to the instrument panel. I dismantled the instrument panel and found the gauge to be in good condition. DO you think it might have to do something with the tank? It sucks because I have to guess how much gas is in the tank. HELP!!
    Thank you
  2. 1971 Mercury GT
    1971 Mercury Comet
    45 views and no one has an idea?
  3. Jamie Miles
    Alto, GA
    I've had a few
    When you say the hazards come on, I assume you mean both tail lights are flashing not matter which turn signal you are using? Sounds like the wires are crossed together somewhere? Of course, as always, check and be sure all your grounds are good.
    As for the fuel gauge, the first thing I always do when working with a non operational fuel gauge, is to take a piece of wire and pull the plug loose from the gas tank. Short the two terminals in the plug together. Then turn the key to ON. If the fuel gauge pegs over to the full mark, then the problem is the sending unit. Let us know what happens when you do that.
  4. mavgrab302
    In my 74 it was the voltage regulator that was bad. It is mounted by the gage on the gage panel.
    But like Jamie said I would check the sending unit first.
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    As for the turn signals if you track the wiring down and don't find any shorts or anything then it is probably your turn signal assy in the column. I have seen alot of people who have problems with them (including myself) so I would say they are prone to failure after 36 years.
  6. 1971 Mercury GT
    1971 Mercury Comet
    Thank you everyone I will update you as soon as I can
  7. 1971 Mercury GT
    1971 Mercury Comet
    Turns out it was the Fuel sending unit. I had it replaced. And for the turning signals I guess the turn signal assembly on the column was faulty. I also had that replaced.
    Thanks again everyone!!
  8. markso125
    markso125 Member
    Lewiston Ut
    cool glad you got it all working :bananaman
