Fuel Gauge: Running on Empty
Discussion in 'General Maverick/Comet' started by Renton5, May 2, 2015.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
  2. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    Melvins has two sending units for 70-77 mavericks and comets in his catalog. Have you checked with them?
  3. Renton5
    Renton5 Member
    Van Nuys, CA
    Wow! I've not heard of them! Thank you very much! I've heard that maybe the float
    is bad, now I can replace it! But I probably should just replace the unit. Looks like
    a quality unit will be about $100, I'm thinking anything cheaper will probably be poor
    quality.
  4. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Have you checked your float? If it has a pinhole in it it will fill with gas and read empty you can get a replacement on E bay real cheap I paid Twelve bucks for one that was all that was wrong with mine.
  5. rthomas771
    Melvin's has the float for $10
  6. Renton5
    Renton5 Member
    Van Nuys, CA
    Hi rthomas771,
    Was the original float not made of metal? I certainly would like to save money and
    ONLY have to buy a float, but then after I put it all together and try it, it may still
    not be a float issue so getting a new unit would've been the better idea.
    Another question: When I drain the tank, I was thinking of syphoning into another
    vehicle, but at the funnel, put in a couple coffee filters to make sure clean gas goes
    in--will this work?
  7. rthomas771
    Renton5-
    I might be wrong but I think all Mavericks came with a metal float. If it was me ...I'd get the unit and the whole 9 yards (0-ring and new lock ring) because I know my luck. The 3 or 4 times I replaced a sending unit I had to remove the tank from the car and stand it on it's edge with the sending unit facing up to seat the sending unit or it would leak. Then again maybe that's just my luck. Use a brass drift punch to remove/tighten the lock ring...you don't want to use a screwdriver or hard metal to create a spark or the last thing you hear might be a big boom.
    I always drain all the gas I can in a 5 gallon gas can by removing the fuel line then pour the gasoline into another car or lawn mower. I also used a clean cloth rag because I don't drink coffee and don't have coffee filters. I would think the coffee filters would do the job too. Once I drain gas the best I can then I loosen the sending unit and carefully catch the last of the gasoline that is still in the tank.
