fuel injection distributor with a carb'd car?
Discussion in 'Technical' started by random hero, Mar 31, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    how would i hook up a distributor with a module on it...any hints, not sure how to go about it :huh:
  2. Dave B
  3. bmcdaniel
    Yep, depends which distrributor. In an EFI car the computer controls the spark timing, there usually isn't an advance mechanism so the only thing you can set is initial advance. You could run a lot of advance, 30*-36*, I guess it would be same as carbed guys running a locked out distributor.
  4. random hero
    hudson valley
    1972 maverick
    it's a whole 5.0 HO motor out of an 88 mustang gt.
  5. RatRodRivett
    RatRodRivett Member
    Austin TX
    1976 4D Maverick
    Since I've joined the forum I see that many people go with the 5.0 HO rather than a 351W, what are the advantages?
  6. Dave B
    Size being the biggest factor, and ease of installation.
  7. Bryant
    if you takeing a fuel injection motor and puting a carb on it you should get the distrubor for 85 mustang with a 5.0 and manual transmission. it has the proper gear for the cam, a vac advance and mechanical advance. it works with the ford duraspark box or with a msd ignition box.
    people are choseing the the 5.0 ho over the 351w because of the ease of installation. primarly its the exhast that is the problem. the shock towers are really close to the the heads. there are mods that can be done to to the shock towers and there are headers that work but they are expensive. you can build a 347 stroker motor that fits in with out any problems that you would have with a 351
  8. mean_maverick
    run a distributor from an '85 GT 5sp car. it has a duraspark setup plus will work with a roller cam as these came with a steel gear. they're like $48 at your local Advance or other parts house.
    that's your best bet :)
  9. random hero
    hudson valley
    1972 maverick
    awesome, thanks guys :dance:
  10. RatRodRivett
    RatRodRivett Member
    Austin TX
    1976 4D Maverick
    Do you mean that the small size will help on the decrease of modifications to install it in a Maverick? Thanks Dave
  11. mean_maverick
    yup, because of the tight clearence between the 351w and the shock towers
  12. RatRodRivett
    RatRodRivett Member
    Austin TX
    1976 4D Maverick
    Do you know if the Ford I6 Flathead 308 bolts right on? I just like the way it looks.
