Fuel regulator
Discussion in 'General Maverick/Comet' started by TommyGun1928, Jun 25, 2020.
  1. TommyGun1928
    TommyGun1928 Member
    Prescock Az.
    1971 Maverick Grabber
    Hi guys I have a question, I'm installing a fuel pressure regulator on my 71 Grabber and would like suggestions on how to rout the return line. Been to u-pick it and found some straight hard line for some sections and planed to using soft line on the rest, what do you think?
  2. 71gold
    sounds like a plan...
    I got another 3/8" hard line from another Maverick and ran it along beside the stock line.
  3. Powerband
    Powerband Member
    NY's \H/
    'easy bend' C/N 3/8 brake line makes it simple.
    for the SC' 250, elec pump at tank uses OEM line to engine compartment's boost referenced- bypass regulator then return line follows the OEM to tank and into OEM filler tube .
    have fun
    / [​IMG] .[​IMG] . [​IMG]
  4. TommyGun1928
    TommyGun1928 Member
    Prescock Az.
    Thx 71gold that was my plan. Thanks for the pics Powerband the return line to the fill spout is a good idea, I was planing on dropping the tank and using the vent line as a return.
