Fuel sender not Ohming out...is it possible to fix?
Discussion in 'Technical' started by jeremy, Jun 10, 2014.
  1. jeremy
    jeremy I build t5's
    Corona, Ca
    My original 72 fuel sender isn't ohming out...so it's no good. Not sure why they die like this.
    Is there a way to fix it? What stops working in it to keep them from ohming out, they seem like a pretty simple design
  2. jeremy
    jeremy I build t5's
    Corona, Ca
    well, quick update, i took a wire wheel to all the electrical contact points and cleaned it up real good, and it's ohming out again! excited now, just saved $100 on a new one
  3. jeremy
    jeremy I build t5's
    Corona, Ca
    I need a new float...I see a lot that look like they'd work. Are floats generic? Would one off a mustang work, or do I need one specifically off a maverick?
  4. Krazy Comet
    Any float that's similar in size and attaching method should be fine, just has to "float"
    If yours is brass, most of the time it's easy enough to solder the crack or hole...
  5. jeremy
    jeremy I build t5's
    Corona, Ca
    thx, "looks" like plastic, it's pretty mangled and covered with tarnished fuel. I've been looking at the vintage brass mustang floats, and I think it may work...at $10 I'm gonna order one and try it out.
