fuel tank pickup?
Discussion in 'Technical' started by newtoford, Nov 1, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    so my 70 ran out of gas today. i got it up to the gas station and put 3 gallons into it befor fuel started spilling out :16suspect
    the part of the tank furtherest to the rear towards the driver's side had a nice punched up area. nothing that looked really hard though. me and my buddy are thinking the pickup got knocked up towards the top of the tank and is only sucking up the top 3 gallons and then is no longer sumerged
    but i would think the pickup would be in the bottom of the deepest, furthest foward part of the tank and a dent in the back wouldnt be anywhere near the pickup?
    (this is a "drop in tank" car with a non-functional fuel gauge)
  2. blugene
    Time to open it up and look inside, if you don't want to keep stoping for gas. Might get a seal so you can at least put it back together, just an idea.
  3. Mavman72
    Are you sure the fuel pump didnt fail Tony??
  4. newtoford
    newtoford Member
    New Castle Delaware
    i can hear it pumping (its electric)
    it still had spark but it took a while to even sound like it was going to want to fire. i think it took that long to re-prime the fuel lines up to the motor from the tank?
  5. Mavman72
    Might want to check the electrical connections for the pump.Yeah they need to prime up before it will run again.Its possible the screen fell off or the tube broke away from the pickup when that tank acquired its dent.Pull the pick up assembly and inspect it.
    Good luck...
  6. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
    can you remove the filler neck an look down in side easily?make sure nothing forein got sucked in the pick up as well.
  7. newtoford
    newtoford Member
    New Castle Delaware
    finally pulled it out this weekend. the pickup rusted off and i still have to get the lower part out of the tank. and im guessing my gauge didnt work because it was all rusted together and the lever wasnt moving
  8. mxer_168
    mxer_168 Member
    Michigan
    1969.5 Maverick
    I had the same problem with mine the day i bought it, what a night that was:16suspect. 3 hour trip turned into 5 hours. finally my friends and I found out that if we shook the car side to side when we were filling it, it actually filled up. When i got home the tank was leaking so I took the tank to tank renu. Im curious to see if my tank will take gas normally now. I just got it bolted in and i will be filling it tomorrow so I will update on that.
  9. mxer_168
    mxer_168 Member
    Michigan
    1969.5 Maverick
    Sorry I'm so late but yeah taking it to tank renu completely fixed it.
  10. 71gold
    thanks for the update...:Handshake
  11. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    What did it cost to have the tank sealed with Tank Renu?
  12. borris
    borris Member
    Oregon
    Maverick
    Interestingly, this new ethanol bended fuels we use tends to strip the old varnish pretty well. The place I would look is the primary fuel filter. I'm willing to bet you didn't run out of fuel, but the carb became starved for fuel maybe? I ran out of fuel a few days ago, but.... it still had 3-4 gallons in it. When I filled it up, it seemed to go for about 10 miles when it proceeded to run out of fuel again. Turned out when I replaced the fuel filter, life was happy again.
