fuel tank woes (efi)
Discussion in 'Technical' started by bomrat, Mar 12, 2015.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hi, on my 74 comet. I am getting cavitation issues , fuel starvation when my fuel tank gets below 1/2 tank.
    any efi tanks out there yet? I am looking at ricks tanks to get one fabricated...
    any other vehicle tanks that would work?
    thanks
    arlan falk
  2. mojo
    71gold has efi and a custom tank w/ sump. Haven't heard of him having any issue as I recall.
  3. 71Mavrk
    71Mavrk Member
    Nevada
  4. injectedmav
    injectedmav Member
    Georgia
    You need a sump. Mine does the same thing. I am going to modify the tank when time allows. Frank's modification looks good. Check it out.
  5. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Theirs 3 solid options
    Most expensive
    vaporworx tank witg flowworx mod and pressureworx(or was it flowworks) controller via ricks tanks
    no filters nor fpr needed
    Option 2
    Ebay ss stang tank
    Aeromotive 340 phantom kit
    aeromotive voltage pump regulator
    pre and post filter
    Option 3 cheapest, most power
    spectra tank
    fuelab intank power module
    Fuelab electronic FPR
    holley hydromat
    pre and post filter
    Ps sumps will usualy still have issues with gforced like i autox and low fuel.
    3 options ive listed above will work well at 1 gallon and on/off track
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Are you running an external pump? If so you could put a small reservoir before the pump. That's what JTR recommends in their efi swap book.
  7. tody
    tody Member
    cologne, germany
  8. 71gold
  9. Bryant
  10. 71gold
  11. tody
    tody Member
    cologne, germany
    list price sure is wrong, aeromotive lists it at just below $500
  12. 71Mavrk
    71Mavrk Member
    Nevada
  13. 71gold
    thanks, but...help me understand... is there a ring inside the tank with threaded holes? if so, how do you get it inside? it looks to be larger than the hole in the tank. maybe I'm overthinking this.
  14. injectedmav
    injectedmav Member
    Georgia
    My VDO sender came with a threaded ring that had a notch that allowed it to be installed through the hole in the tank. I used one screw to hold the plate in place so you can start the others after dropping the assembly through the hole.
    71gold likes this.
  15. 71Mavrk
    71Mavrk Member
    Nevada
