Funny click when brakes are pressed???
Discussion in 'Technical' started by Jerilyn, Nov 16, 2005.
  1. Jerilyn
    Jerilyn Member
    Beautiful Las Vegas!
    1973 Maverick
    Awhile back I noticed that there was this funny click when I pressed the brakes. At first I thought that maybe I had a sticking caliper (did the disc swap a few years ago) so I took it in (no space to work in our garage) and assumed that I needed a brake job but they said that everything was within spec and since it was only happening occassionally to bring it back when it did it more often. Well I did become more frequent so I took it back, husband was almost sure (after many a trip around the block) that it was in fact something in the suspension. We changed the control arm bushings and the noise went away for awhile but it's back now. It's always when you break and the weight is pushed to the front of the car. Any ideas? Almost everything suspension wise is new. It's driving me nuts.
    Oh yeah and while I have you guys here, I've noticed that lately when I turn my steering wheel to make turns (more so when I turn the wheel to the right) it whines something aweful. Is this a belt? Too tight maybe? The pump is only about 2 years old, the power cylinder is a little under a year. Any ideas. Thanks so much.
    Jeri
  2. Jamie Miles
    The whine is probably because it's low on power steering fluid.
  3. Jerilyn
    Jerilyn Member
    1973 Maverick
    Already checked that sorry, I should have posted that too. Maybe a clog somewhere?
  4. Mavaholic
    Check your wheel bearings. I think the whine is in the ps system. I've had some that whined rediciously loud even though they were full of fluid.
  5. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    if the noise is in the pump try some synthetic PS fluid Ive had good luck using it ,as far as noise in front it sounds like the anti rattle clips are gone or collapsed they go between caliper and bracket
  6. Jerilyn
    Jerilyn Member
    1973 Maverick
    Thanks guys. Mavaholic, the wheel bearings were done about 8 months ago. I will check the anti-rattle clips again. I'll let you know what it is.
  7. stmanser
    Davenport, Iowa
    check the strut rod bushings.. mine makes a noise as well when i hit the brakes and take off.. and i know my suspesnion needs work, but the strut rod bushings on mine are definitely worm..i can see the rods moving..
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i would check the suspension parts for slack that would cause the click.
    the steering whine could be an air bubble in the system, does it do it before the wheel is cranked to its full movement?
  9. Jerilyn
    Jerilyn Member
    1973 Maverick
    The whine starts when you begin turning the wheel and doesn't let up until you stop.
  10. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Any signs of leakage,even very little seepage,aroud the steering sector(gear box)????Do you have to add p/s fluid,even very little.....It sounds like there is an air bubble in the system......as for the braking noise,Do you have drum or disc brakes on the front????Either way,look at the shock mounts very close and the control arm bushings....
  11. Jerilyn
    Jerilyn Member
    1973 Maverick
    No leakage. No need to add ps ever. Disc in the front, drum in the back both withing spec and nothing is loose. Control arm bushings are new and tight. Maybe I'll look at the shock mounts though. thanks
  12. hotrod-daddy
    hotrod-daddy Member
    I would have to look at it personally to diagnose it properly.....
  13. Mavaholic
    Did you find the clicking? Whine is probably just the ps pump. I had a Bronco just like that. Worked fine but very loud whinning pump.
