Fuse Panel
Discussion in 'Technical' started by dschrodt, Nov 27, 2010.
  1. dschrodt
    dschrodt Member
    Ellijay, Georgia
    1969.5 Maverick
    I keep reading the cool tech article on the fuse panel update, and was digging around the garage and found I had one of these:
    Since I am not very adept at the electrical stuff, I am not sure I understand why there is only 1 blade per fuse, would something like this work for replacing the current glass fuse block? Seems like I would have an awful lot of wires going into a single plug for a few of them.....
  2. ptpdub
    ptpdub Member
    canada Sk.
    a power wire goes into the post with a nut on it. then power is split and runs threw the fuse and into what ever electrical device you have.
    the fuse block you found is too small to run more than around 8 things and therefor should be considered an add on and not a replacement.
  3. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Look at it like water. As ptdub said, the water goes in thru the screw. Then it is piped out thru the 6 connectors (3 per side). The fuses are inline, just like a shut off valve.
    The other electrical wire your worrying about is at the device (radio, fan....) it would be the ground wire.
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Just to note, not all the fuses on our Mav's have "power" on one side of the fuse. Several are wired "in-line" style and although they get their power through one side, it's from a source other than a common post.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    this is how we upgraded it . . .
  6. Mavaholic
    Well, no, all fuses have power on one side only.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Guess I wasn't clear. :hmmm: Not all the fuses get their power from a common buss. Case in point: check your dash illumination circuit (blue/red) fuse, yes it has power on one side but it gets that power from the light switch, not a common buss.
  8. 71gold
  9. mojo
  10. 71gold
    in the same location as the stock one...:thumbs2:
