Gas smell in oil ?
Discussion in 'Technical' started by 77cometman, Apr 21, 2006.
  1. 77cometman
    77cometman New Member
    va
    1977 comet
    Just changed the oil in my 77 comet 302 V8...Both the dipstick and the oil from the oil pan smelled like gas...Previous owner had last changed the oil in 2001...Can anyone tell me what would cause this ? Thanks, in advance...
  2. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    pretty normal imo, old oil, old car. A little gas is getting past the rings...
  3. Jamie Miles
    Alto, GA
    I've had a few
    I wouldn't worry about it to much. Change the oil and have fun.
  4. don graham
    if it's 5 year old oil i wouldn't worry about it too much, but i would change the oil in say another 1000 just to clean things out completely. you don't get all the oil in one change.:)
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    is that the old or new oil that has the smell? how many miles on the old oil? what does it look like? you get a little gas in your oil with regular use. but if it is a lot, you could have a bad intake manifold gasket, bad intake manifold, etc... do you have any other odd symptoms?
  6. rayzorsharp
    I'm betting the diaphram on your fuel pump is leaking. It will pump gas straight into the oil pan. A new pump and change of oil will most likely fix the problem.
  7. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Another thing that can do that is a dirty needle or float that's too low. When I rebuilt my first carb I got something wrong.. the fuel pressure in the line kept pushing gas into the carb/intake, and eventually the crankcase as it washed down the cylinder walls. Ended up with about 5 quarts of gas in my oil overnight. :yikes:
  8. scooper77515
    Wait til you smell the differential oil and old tranny fluid...
  9. don graham
    ahh, nothing like the smell of good old burnt differential fluid. :yikes:
  10. stmanser
    Davenport, Iowa
    i will 2nd this,... seen it before..
  11. Grabber5.0
    Kansas City, MO
    71 Grabber
    No kidding, when I took the 3rd member out of the Grabber, the smell about knocked me over! [​IMG]
  12. 69 ina 1/2
    I got a "new" unopened bottle of friction modifier in the garage, double wraped in plastic bags and the stink still makes its way out somehow. Yuck
  13. Craig Selvey
    Man....that stuff does stink!!!
  14. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Wonder what makes it stink so much?
  15. Grabber5.0
    Kansas City, MO
    71 Grabber
    Funny how all us gearheads like the smell of gas and oil, but we all hate the smell of diff. fluid. :D
