gas suprised...
Discussion in 'General Maverick/Comet' started by 71gold, May 20, 2007.
  1. 71gold
    when i went to Jax-ville this weekend i had a chance to check the gas mileage on my new motor...:D
    got 19.58 MPG @70-75 MPH with/A/C chilling... (y)
    thats 2.0 MPG better than my old motor.:yup:
    "love my AOD" :bananaman :bananaman
  2. don graham
    practically paid for itself already.(y) good deal frank.:)
  3. rayzorsharp
    Cool beans...but at $3.00+ per gallon, you still probably spent about 2 grand on gas, huh? :cool:
    I really wanna convert my toploader over to a 5 or 6 speed in the near future. :burnout: Should be much more pleasant to drive. :cry: What am I sayin??? Hot rods ain't s'pose to drive pleasant, are they? :huh:
  4. 71gold
    if you drove it somewhere besides up on and off a trailer it would be more pleasant now. :boxing: :hmmm: if a 4-speed is "unpleasant" to drive then how could a 5-6 speed be better? :huh: ..change the rear gear...
    i don't understand why people spend the time and money to build a car they can't :drive: . :slap:
    i stopped coming back from Jax-ville to get gas, a guy inside the store said "thats the best looking maverick i have seen in a while". then he asked "may i go out and look at it?"
    the guy running the store left the counter and came outside with him. i opened the hood and showed them the motor and the guy running the place aske me to waite a min. and he went back and got his camara and took pics. of the first guy and my car.
    at the same time there were 3-4 people waiting at the counter to be checked out. they were even looking like it was something "SPECIAL"
    that's why i :drive: mine..."what color you going to paint it comments and all."
    ...:Handshake ...
  5. rayzorsharp
    Exactly...I love the shifting part. That's why I changed to 4 speed. :bouncy:
  6. 71gold
    $3.05-$3.17 for the reg. unleaded i run..
    "Still have to shift but thats what hot rodding is all about right."
    no..no..no..no..nooooooo :tsk:
    AOD is what :drive: a Hot Rod is all about (y)
    ...:bouncy: ...
  7. rayzorsharp
    Yeah, whatever...automatics are for sissies...or OLD RETIRED GUYS!!! :drive: :) :) :)
  8. 71gold
    ...getting OLD or RETIRING :huh: :rofl2: :biglaugh: :D
    ...:cool: ...
  9. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    There is nothing more entertaining than watching two geezers squabble at each other.
    Well, gorgeous babes mud wrestling might be more entertaining.
  10. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Great to hear Frank! I`d Love to put a Gear Venders Overdrive in my car, bolted to the back of my Fully manual C-4 .... but first I need to win the lottery.
    I did check my mileage on the trip to the show at AMS and I got right at 15 m.p.g.:bouncy:
    No big deal though... I didn`t set out to build my car to be an interstate cruiser anyhow.:burnout:
  11. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    I'm with Mike. I'd like to put a Gear Vendors behind my T-10...that is currently sitting in my collection of parts for the day they become a Maverick.
  12. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    I'd say that is very good mileage, do'nt know what all you have in new motor with some hopup goodies i'd still say thats good. Going to get exhaust on the blue car tomorrow then hopefully will see how the AOD works in it. had to move collecters out about 3'' to get AOD up in so have to have new pipes back to mufflers.
  13. M.A.V.
    Macon,Georgia
    I have a buddy who insists on haveing Overdrive in everything he owns.
    The general rule based on his installations and everyone else we have spoken to about it is:
    You will gain around 4 miles per gallon
    from installing an overdrive in a V-8
    powered car.
  14. 71gold
    glad you asked...(y)
    Motor Build for...Patches...1973 Ford Maverick Grabber
    Block-1987-FORD Mustang-5.0
    Align. Honed
    Bored- .030...306 c.i.d.
    Crank-Stock-1987-5.0- .010/.010
    Bearings-Seal Power
    Pistons-Hypereutectic-Flat Top-4.030in.
    Rings-Hastings-Chrome
    Rods-Stock-Resized-ARP Bolts
    Balanced-0.2 oz-in Target
    Compression-9.5:1
    Oil Pump-Melling-Standard
    Oil Pump Shaft-ARP
    Fuel Pump-Summit-80 GPH
    Timing Set-Comp Cams Magnum Double Roller
    Water Pump-Advance Auto-Standard Rotation
    Headers-Hooker 6901
    Cam Specs.
    Cam-Trick Flow Track Heat-Hydraulic Roller
    Firing Order-351...1-3-7-2-6-5-4-8
    Duration-Intake 275/Exhaust 279
    Lift-Intake .499/Exhaust .510
    Lobe Seperation-112 Degrees
    Cam Advanced-4 Degrees
    Roller rockers-Crane Energized 1.6
    Lifters-Stock 5.0- Roller
    Push Rods-Ford Racing-5/16 in.- Hardened
    Heads-Non Emission
    SBF-AFR 165 Outlaw Street/Strip
    Combustion Chambers-58cc
    Rocker Arm Studs-3/8 in.- Screw In
    Guide Plates-AFR
    Valve Job-3 Angle
    Ports-CNC Ported Intake/Exhaust
    Valves-1.90 Intake/1.60 Exhaust
    Valve Guides-Bronze
    Head Bolts-New- Stock
    Intake-Edelbrock Performer RPM
    Carb.-Holley 4160c-750 CFM- 4v-
    Vac. Sec.-Electric. Choke-Polished
    Coil-Pertronic Flame Thrower
    Dist.-MSD- w/Crane Cams Hardened Gear
    Plug Wires-MSD 8.5mm-(RED)
    Spark Plugs-Autolite-AR3924
    Dist. Cap-MSD-(RED)
    Harmonic Bal.-Ford Racing
    Gaskets-Fel-Pro
    Transmission-1984-f150-AOD
    Rearend Gear-3.55
    Posi. Traction- Powertrax
    Dyno Results-EngSpd RPM---NR--- -WhlPwr HP---NR---
    WhlTrq lbs-ft- ---NR--- -Speed MPH---NR---
    The Crew
    Motor Specs. by- Mike A. Vaughn...Thanks...(M.A.V.)
    Machine Work by- Wheeler Machine...Thanks...Wesely Grimes
    Rotating Assy. Bal.- Walker Performance...Thanks...Chris
    Motor Build- Harold Etheridge
    To be Dyno by-Reeves Performance...
    Special Thanks to......
    my Loving Wife...Effie Cooper...Thanks...(Sweetie) XOXOXO
    plus...$2,000.00 for odds and ends.
  15. 71gold
    looking foward to hearing how the AOD does..i love mine...(y)
    remember..."you can only use OD when going down hill."
    ...:burnout: ...
