Gas tank help please
Discussion in 'General Maverick/Comet' started by SlotlessMan, Apr 19, 2014.
  1. SlotlessMan
    SlotlessMan A squirrel and his nut
    Chetek, WI
    71 Grabber
    Can someone please tell me what tank this is? I don't believe its original.
    Its leaking and needs to be replaced.
    IMG_2560.jpg .
  2. Craig Selvey
    I would say it is a Mustang one. One that is used in the conversion from a Maverick tank. I see the straps have been moved over to center the tank.
    Where is it leaking?
  3. SlotlessMan
    Chetek, WI
    71 Grabber
    Thanks Craig and I agree, I think it is a repop of the 65-68 Mustang tank but wanted to ask you guys before I just buy one.
    It has small a couple of rust spots on the bottom that are seeping thru. Funny that its doing that already as I expect its probably less than 10 years old. Looks like there a couple different metal/ brand tanks made out there and this one seems to be the cheaper (Silver color) of them.
    Being the sending unit and gaskets are fairly new I will just probably get a tank and not the kit. I expect to go with this one on Monday unless the consensus is that the tank is something different.
    http://www.cjponyparts.com/fuel-tank-with-drain-plug-premium-1965-1968/p/XFT2/
  4. 71gold
    the drain plug seems to be in an odd place...:yup:
  5. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    Drain plug is in the same place mine is.
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Same here (69 Mustang tank)...
  7. Tannersg1
    Tannersg1 Member
    Classified
    Just ask Lonnie!
  8. lukejena
    lukejena Member
    NE Iowa
    How did you get the 50's under her, I like it
  9. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Minitubs and springs relocated 3" inboard, lots of work but 325's fit great!
