gas tank pressure
Discussion in 'General Maverick/Comet' started by mavtricks71, Mar 25, 2007.
  1. mavtricks71
    mavtricks71 Member
    the blue canistor that sits on passenger firewall that connects...to gas tank line ....is that to relieve pressure? i got rid of canister , droppeed tank and plugged up the the top fitting....on top tank, i have a ton of pressure now...did i create a bomb? or use vented gas cap?
  2. luckyirishpride
    luckyirishpride "Youngest Comet Owner"16!
    Southern California
    2x 1971 Mercury Comets Both V8s, P/S/, A/C
    That line is the vent line. Dont just plug the hole... I would just run a little line somewhere where it will be shielded and put some sort of filter at the end to keep crud out.
  3. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    The cap is not vented so by eliminating the vent you can pop a tank when the warm or hot temps make the gas expand.
  4. Mavaholic
    The blue canister is a carbon filter that routed the gas fumes to the carburetor to be burned.
  5. 71gold
    ...and on a carbed. motor it can push gas pass the needle and seat and fill the bottom end (oil pan) with gas...the bomb you were speaking of.
    ...:hide:...
  6. mavtricks71
    mavtricks71 Member
    guess i got some work to do....
