Gas tank?
Discussion in 'Technical' started by TheMaverickBoy, Oct 27, 2007.
  1. TheMaverickBoy
    TheMaverickBoy Member
    Portland, OR
    1974 Four Door Maverick with a 250 straight six(Now in that big junk yard in the sky), Currently a 1976 Mav with a I6 250 soon to have a 2bbl carb and dual exhaust, ooo yeah
    ok.... so I think I narrowed it down to the fuel sending unit. The car likes to stall out ocassionally. its like the car is out of gas, but its not. which I think means there is something in the gas tank which isnt cool. SO, before I drop the tank since the gas gauge doesnt work I want to grab a fuel sendng unit to replace it. But no where has it. I did a search up here and saw Autokrafters, but which one do I need? do I need the one from the T-Bird or truck?
    thanks guys...
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Auto Krafters 1-800-228-7346 shows part number D1DZ-9275A for a 74 Maverick.
  3. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    There is a cloth sock on the end of your sending unit that can act like a flap and restrict gas flow. On mine it was pluged so I took it off & ran two filters in line. If your gauge is reading right it could be the sock inside the tank on that unit that is causing you a problem. I would check that first sending units get alittle high $$
    GOOD LUCK!
  4. Craig Selvey
    Auto Krafters has a fuel sender for a 1974.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I see what he's saying. On the auto krafters website 2 units come up for a 1974 mav. Model B8S-9275A and B8C-9275B. But in their catalog it's part number D1DZ-9275A that you need for your car. And it looks like it's $70
  6. TheMaverickBoy
    Portland, OR
    sorry, its not the 74, its the 76. are they the same unit?
    Also it died again on my way to work, when it dies it kinda sputters, it doesnt back fire through the carb. it just kinda slows down the RPMS it sounds and feels like and then sputters till dead then wont start for a few moments, then it might or might not. What I have done in the past to fix it is suck gas through the line under the hood and since it take a lot of sucking it would seem as though there is a blockage. after that to make sure I have gas in the line I throw some starter fluid in there and fire her up. But it has done it 3 times in the last 24 hours. God knows its cold but it shouldnt affect it that much.
    I should drain and drop the tank now but I dont want to chance the unit being completely crapped out and not having a car for how ever long it takes to get it..... :cry:
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Temporary fix and aid for troubleshooting,, With LOW air pressure, take gas cap off and reverse blow into the gas line tank side of the fuel pump. Remember use LOW air pressure and don't have your buddy smoking at rear of car! (only ex's are allowed)
    May want to Pb blaster the holding straps for the tank a couple days, here in the rust belt, pretty much a sure thing on replacing them, not sure how rusty yours are.
    After you blow threw line, you may want to siphon tank empty, filter gas, fill back up, re-siphon several times an see if you can get much "junk" out. May keep you running better till you get your parts in an replaced. Good luck!
    PS, blow threw line will usually knock that sock off the in tank line, my opinion, that's a good thing other than it's still in the tank
  8. GrabA72Mav
    Eastern Iowa
    dkstuck: thats a good idea to get him going. Like I said before does the fuel gauge work?
    If it works you don't need a sending unit all it does is tell you how full the tank is or isn't.
    Sound like you have a on & off plugging of your line that is getting worse as long as your fuel pump is good. Good Luck!
  9. TheMaverickBoy
    Portland, OR
    yeppers, the fuel pump is still good, I already figured on replacing the belts, but thanks for the tip.
    blow through the gas line huh.... that kinda makes sence.... :16suspect
