Gasoline octane
Discussion in 'General Maverick/Comet' started by rosalindr, Jul 22, 2005.
  1. rosalindr
    rosalindr Member
    Northern Califonia
    1973 Yellow Maverick Grabber
    I just bought a 1973 Maverick Owners Guide. It recommends 91 octane gas. In 1970 I think that was medium octane. I have the 302 V8. Is it worth it to use the high test now? What difference will it make to use 87 octane?
    Roz
  2. 74merc
    74merc computer nerd
    1974 Comet
    73 should be 8.5:1 compression, 87 will run fine. Might need 89 on hot days...
  3. Jamie Miles
    I don't think you'll have a problem just running regular old 87. I don't...
    Edit: 74 Merc beat me to it!
  4. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    As long as it's not spark knocking I'd think you are fine.
    On another note any of you with higher comepression running the zyleen type homemade octain booster?
  5. 71gold
    if it knocks...bump the timming... i don't think it will...frank...:bouncy:
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Shouldnt knock,, but if it does, dont answer it,, you never know who it could be.:rofl:
  7. papawdarrell
    papawdarrell papawdarrell
    Arkansas
    1973 Maverick
    My 73 has run fine for the last 28 years on the lower octane....Never had a problem
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    My old 84 pickup with the 351 won't run without knocking on anything less than premium. I'd say start with the lower octane, run a couple of tanks full so you get a good variety of roads and conditions and then if it knocks, move up a grade and do the same thing again. There are plenty of octane boosters on the market that are reliable, good products, so I wouldn't mess around with homemade stuff.............don't know whats in it, could mess up more than it helps. Just ask Dan Hines, diesel won't run too good in a gas burner! :rofl2: Oh, I forgot , that was a accident!:rofl: :rofl:
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    The 351 in my 71 F100 is about the same way, it will spark knock on mid grade unless I retard my timing. I realyy think I need a better cam.
    I have played around with the home-made octain boosters with pretty good results.
    I mixed about 12 oz of Zyleen in a tank full and I can run on a quality low grade with very little spark knoc, mid grade with no spark knock.
    The home-brew web page said that Zyleen and Toulene is used by the gas makers to adjust the octain.
    clint
  10. kansas_grabber
    kansas_grabber Member
    Lawrence, KS
    73 Grabber
    Where can you purchase those chemicals from?
  11. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Im interested in the homemade octane booster also.
    May/may not use it but would like to know whats involved
  12. skate1274
    skate1274 Member
    St.Pauls North Carolina
    1974 mercury comet GT
    I doubt it will knock . Probally will just vapor lock.
  13. Andysutt
    Conway Arkansas
    1972 Comet GT
    can you explain your vapor lock theory?
  14. scooper77515
    I got this off a google search, which was a quote from a quote found on a Corvette forum. Apparently, it is "XYLENE", unless that is just the name brand of what I have.
    Kool thing is, I have had a gallon in the garage for cleanup for years, and never knew this.
    Wish I needed it for this reason :huh: I don't think it would affect my 8.0:1 compression (that is what I have in the 74, isn't it?).
  15. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    That's the one I'm talking about. You can do a web search on Home-brew octain booster and come up with alot of information.
    I used the stuff several times when our truck club went to the test-n-tunes to play around with our trucks and do some grudge type racing.
    My 351w powered F100 took down a lighter truck running the famous 390 FE. lol
    A wopping 10.01 in the 1/8th mile woohoo. BUT that was with my camper shell on plus my tools in the back. lol
    clint
