where can i find a circuit board that goes behind the gauge cluster, the connections on mine are peeling of and arent connecting with the plug.
How is your white plastic? I find that is usually the problem with the guage cluster. They crumble and turn to dust over time.
Yep, I tried to hot glue my metal in place, and it worked for a short time. Ended up needing to buy the entire new plastic sheet. And found out the hard way that there are (at least) two different layouts, so be careful what you purchase. One plug is a bit wider than the other.
