Good aluminum radiator?
Discussion in 'General Maverick/Comet' started by William623, Dec 21, 2015.
  1. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Thinking about putting a new radiator in the car. I am running a 302, nothing fancy. Any recommendations on a decent 3-row radiator? Preferably in the 150 range but I am definitely open to suggestions!
  2. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I just bought a Champion 3 row. Very nice quality! The only issue is the drain port is not usable. Probably a bit more than you want to spend, but its worth it.
  3. yellow75
    Tillamook Oregon
    I think you will find out that most people will tell you a Champion radiator is what they are running, good fitment except for the drain petcock has an issue with part of the frame cross brace needing to be trimmed a touch. Havent looked at the prices lately but are in that area
  4. William623
    William623 Member
    Orlando
  5. yellow75
    Tillamook Oregon
    Do a search for Champion cc339 and you may be able to find one cheaper
    NCFatBoy likes this.
  6. William623
    William623 Member
    Orlando
    Thanks for the part number, I was able to find one a bit cheaper. Still need to do a bit more shopping around though.
  7. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    I use Champion radiators in all my cars. I talked with them about the petcock fitment, I asked them if they would put it on the bottom and they did. The radiator fits better and theres no more splatter when draining it.
    The pictures are of a 2 core with 1" cores sitting in a 73 Comet.
    I have a 3 core in my 70 Maverick and it still took a little shaving to fit but not much.
    NCFatBoy and Kenn like this.
  8. William623
    William623 Member
    Orlando
    My next question, do I really need a 3 core? I currently have a stock 2 core in my car right now, the engine will run about 190 highway and 175 in traffic. I would like to get it a bit cooler because it will get pretty hot in the summer. I already have added a remote trans cooler, and 5 blade flex flan. Would a new 2 core be able to handle this or go to a 3? Thanks for all the input so far!
  9. yellow75
    Tillamook Oregon
    A 2 core would probably be good enough especially if you are running the stock radiator that came with the car originally, you would be looking at about $60.00 to $70.00 dollars or more cheaper with a 2 core. What kind of driving do you do? It may help to go to an electric fan if you do a lot of town driving or stop and go traffic when you dont get enough air movement through the radiator
  10. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi William:
    Been noticing your posts . You might want to consider an electric fan for additional cooling. The "Flex Fans" have been noted to fail and disintegrate and cause serious injury even loss of life . We lost a friend several years ago when
    he was " winging" the throttle to his 302 and the fan separated and one of the blades caught him on the neck and he
    didn't make it to the ER . ( True Story) .. I removed them from our cars long ago . I have a NEW fan still in the box that I purchased many years ago that I'm going to " pitch" I wouldn't GIVE it or SELL it to anyone.Just my personal input.
    Cometized
    (Chip)
  11. William623
    William623 Member
    Orlando
    Nothing too harsh, mostly highway and city driving. I don't push the car to awefully hard. I just put on an electric fan seems to help a bit but still not where I would like. It's actually cooler at stoplights because the flex fan draws a good amount of air.
  12. William623
    William623 Member
    Orlando
    Hey chip,
    I already have a small electric fan on the outside that pushes air through the radiator. But I would be interested in seeing the fan though, I always appreciate the help. Hoping to make a trip up there before my break ends. Good to know about the flex fan, definitely going to have to keep that one in mind...
  13. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    I know what you mean. We rigged up a Pusher AND a Puller fan on the last three cars and it worked out really well..
    The Pusher Fan activates at 185 degrees.. and I have a manual "override switch" that I can turn on when I park or if
    I'm at a traffic tie-up to aid in the cooling process. We took the Comet on a 4400 mile Power Tour last June and didn't overheat once .. even when idling at the stops for long periods of time . The TWO fan setup is extra insurance
    and not difficult to hook up with relays.
    Cometized
    (Chip)
  14. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hello again Will:
    Are you going to make it to the NPD show this coming January 9th at Crystal Springs (Ocala) Florida ? There will be lots of Mavericks and Comets there and you would be able to meet a lot of people from MCCI also at the event. Go early if possible .. sometimes parking can be scarce. Lemmeno if you're going .
    Thanks
    Chip
  15. Krazy Comet
