Got my DISC BRAKES installed. EXCITED! PICS INSIDE.
Discussion in 'Technical' started by 510madmav, Jul 22, 2009.
  1. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    so installation was fairly smooth. bled the FRONT only, very thoroughly. slapped the wheels on and took off down the street.. the pedal is somewhat soft and lower than what i would like, or expected. the rotors seem to have more drag than they should. how much drag is normal? the performance of them was was under my expectations; not as sensitive as i hoped. have i done something wrong here?:huh:
    thanks guys
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Still using a drum master cylinder?
  3. 510madmav
    510madmav Member
    1973 Maverick
    sorry forgot to specify. i still have my stock drum/drum MC and my drum/drum prop valve.
  4. blugene
    Did you modify the brake hose fittings? Just wondering cause if I remember, they point the opsite way.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Oil or grease on the rotor will cause lesser performance.
    Old brake hoses could as well.
    If the pedal is low/soft, I might be looking at bleeding ALL the system, as well as adjusting the rears. That is likely to show improvements.
    Good luck!
    Dave
  6. 510madmav
    510madmav Member
    1973 Maverick
    thank you dave, i'll bleed the rear tomorrow.
  7. Bryant
    the timeless question of does the drum drum master work with disk drum set ups. i suspect that your problem is because the m/c bore is too small for the disks. get disk drum m/c.
  8. Bryant
    is there paint on the rotors? paint will cause the brakes to not work well at all.
  9. rad1j
    rad1j Member
    filer daho
    73 grabber
    use a 89-91 grand marqi master brake junk yards are full of them dump the booster and just use the master cyinder they work great did you put residual valves in front and bac also ?youll need em and they call for diferent pressures
  10. 510madmav
    510madmav Member
    1973 Maverick
    guess I'll be changing my mc. I'll get a new one.
  11. sierra grabber
    sierra grabber Certifiable
    northern nevada
    just get one for a 74 or later mav, non power disc ;)
  12. 510madmav
    510madmav Member
    1973 Maverick
    yep. thanks
  13. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Lot of people say they're still using the drum/drum master w/disc brakes with no problems. I'm in the process of converting mine and will keep the drum/drum mc and proportioning valve for now. What do you have on the back, disc or drums? If your rears (drum or disc w integral parking brake) not adjusted properly you'll have a low or soft pedal like Ratio411 said. Could also still be air or any of the aforementioned problems.
  14. fastback86
    FL
    He must have, I just did mine and did it the same way. They originally went over the hose bracket and looped back around.
  15. Bob Wiken
    Fayetteville, Arkansas
    I left the MC, PV on when I did my conbversiotn. I've had no problems. Goos pedAL but you do have topress hard as you don't have the power assist. pedal is high and firm, like a high school cheer leader
