got to be key cylinder lock
Discussion in 'Technical' started by shayne95, Jun 21, 2015.
  1. shayne95
    shayne95 Member
    Pt Richey, Fl.
    71 maverick grabber
    My 71 Grabber is driving me crazy. It continues to crank after the key is off. It will fire and start only
    if I hot wire it. I have replaced the ignition switch, the solenoid, the coil everything you can think of.
    It also seems like something is shorting out after it spins using the key to start it. The only thing that
    I can think of that I haven't replaced is the lock cylinder. Does anyone agree?
    Gary
  2. Bryant
    maybe the linkage from the ignition switch to the key tumbler is gummed up. you may want to pull the steering wheel so you can pull the key cylineder then try cleaning out the mechanism, put fresh grease on it and reassemble.
  3. rthomas771
    I'm thinking it's the starter solenoid.
    Krazy Comet likes this.
  4. Krazy Comet
    Nope it's only the lock...
    Assuming it doesn't require a bunch of jiggle and shake to operate, you have other issues...
    Agreed...
    Disconnect both of the small leads on solenoid, if engine continues to crank the solenoid is defective...
  5. bmcdaniel
    Or if the two small wires on the solenoid are reversed.
    Paul Masson likes this.
  6. Northern
    Northern Member
    '74 Maverick
    What will the reverse solenoid wire do if your trying to crank it?
