Grabber cowl hood (being made) a new thread
Discussion in 'General Maverick/Comet' started by Jimmy2gates, Mar 22, 2010.
  1. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Well folks i decided to start a new thread as the last one was getting to long and the modification pics were to spread apart.This one will have most of the pics from start to in primer.The hood should be ready for paint in a week or two,still have to clean up the underside.I hope most of you like it ,i do ,its going to look great on my street/strip Grabber racecar Blue Thunder. cheers Jimmy
  2. Jimmy2gates
    Jimmy2gates Member
    71 mav
    More pics of 2 1/2 inch cowl being modified onto original Grabber hood(y)
  3. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Ok folks even more pics of this 2 1/2 inch Cowl Grabber hood modification ,i think its starting to shape up well ,i like it and thats what matters ,RIGHT.
  4. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Well folks here is pics of the final stage of this side (its in primer),this comming week we will do the other side and epoxy primer the whole hood to make to whole hood mint, guide coat it and long board it one last time ,it should be painted and on Blue Thunder in Two Weeks,i like the end result and i hope most of you do to. cheers Jimmy P.S im looking into getting a fibreglass mold built ,to make a hinged glass one and possible Carbon fibre ones also,we will see after it is done and i take it to my local fibreglass mold builder and look at the costs to make them.
  5. Dfitzman
    Dfitzman Member
    Taxachusetts
    1971 Green Machine
    I like it... what I really enjoy is seeing someone marching to the beat of a different drummer. Takes balls to start chopping a perfectly good part to get what you want but it's the only way to be happy with what you have.
    Keep pluggin it will get some looks no doubt and be ready for the "where did ya get that hood" questions.
    Dfitzman
    PS better get the No body mods or cutting whatsoever !!!! out of your sig :)
  6. 71gold
    what are the plans for the opening on the underside (brace) if any?
  7. mean_maverick
    as long as ur happy with it :thumbs2:
  8. Mercurycruizers
    Venetia, PA
    I like it....
  9. darren
    Looks good.
    I think givin the option though I would have liked the top edge a little less sqare. Rounded to match the line behind the scoop. Just a personal preference.
    Looks like really good work though. Cant wait to see it painted.
  10. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Hey Frank(71gold) to answer your question ,we cut out the two small braces that go from the sides at the back of the hood and go to the center of the hood at the back near the cowl .You can now get a 16 inch air cleaner in there and not touch anything and the hood is still really tight and strong. The rest of the bracing is still there and it looks factory.Here is a few pics of it on the car when we were test fitting for NOS plates and a 3 inch high air cleaner,everything fits mint.:clap:
  11. darren
    Are you talking about the 2 that are cut off my hood also? The hood is still very stiff without them and not really noticeable that they are missing.
  12. oppd08
    oppd08 Member
    Bellevue, NE
    70 Maverick, 72 Maverick 4-door
    Great job! I like it too....but I do have 4 camaros....cowl hoods are cool! :dancing::drive::thumbs2:
  13. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Yes Darren ,i did just what you have done ,a little bit of grinding and filler and it looks factory,i dont want to post pics of the underside untill its mint ,but i think when its painted Grabber Blue and the factory silver Grabber hood stripes are painted on it will look pretty good inside and out.
  14. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Hmm.... I thought you would follow the flow of the grabber hood scoops and continue up from there, I think that it would have given it alot cleaner look and made it look like the factory would have made it...(since you keep saying that it looks factory..er...yeah..:rolleyes:..:biglaugh:)
  15. CaptainComet
    Re: the two braces that were cut out...
    I kind of get the feeling that those are there to keep the big expanse of sheet metal from flexing at high speed more than anything. The base of the windshield is a pretty high pressure area (why cowl scoops work better than a lot of the ones that face forward ... :thumbs2:).
    By adding a hood scoop or cowl like you guys did, it would accomplish the same thing.
