Grabber spoiler
Discussion in 'General Maverick/Comet' started by Relivin1970, Oct 3, 2014.
  1. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    1970 maverick,1972 Sprint
    Does anyone have a template for the deck lid for a spoiler install ? I have a old deck lid I would like to test fit a spoiler we got that needs work to check fitment thanks guys
  2. Craig Selvey
    I do....but it will be expensive to ship it back and forth (I will want it back)
  3. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    No way to make one out of cardboard or light plywood?
  4. Paul Masson
    1971 Grabber
    Nobody has a paper one??? Maybe if I get brave, I could take the spoiler off MY car and get a big sheet of paper and trace out the hole locations and the edges of the trunk lid. I could scan it on the 36" scanner at work and make copies, or send PDF's out. I didn't realize everyone was using plywood and cardboard... :huh:
  5. Dave B
    Measure the locations of the studs, then transfer the measurements to the trunk lid, then drill the holes. Do a search, it's been discussed many times over the years.
  6. Craig Selvey
    This is probably the easiest way to do it.
  7. 71gold
    sit the studs on the spoiler up to the lip on the trunk lid. mark there location with a marker and center punch the mark. it should be on the very edge of the trunk lip...use a step bit to size the holes.
    here is 16 year old Collin doing his spoiler install.
  8. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    Thanks for the input guys I just was thinking someone would have a proper template I could use. Cheers
