Granada spindles on a 70 maverick
Discussion in 'Parts Interchange' started by Ford Freak, Feb 16, 2018.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    Hi guys , I picked up a set of Granada spindles complete. But another maverick guy told me that they will not work on my 70 . My maverick buddy up in nor cal said they will .. I’m a bit confused here . Any tips. ?
  2. Krazy Comet
    The early '70(69.5) used suspension like other '69 models but there is no reason the Granada spindles can't be made to work... Main difference is size of spindle increased in '70 and true '70 tie rods will be required to fit into spindle arms...
    I have '69 Torino spindles & brakes on my '72, all I had to do was use the earlier tie rod ends...
    Ford Freak and Maverocket like this.
  3. bmcdaniel
    bmcdaniel Senile Member
    I thought the Granada spindles were the same as late Maverick spindles? I have '76 Maverick spindles on my late '70 (3-bolt ball joint), just needed to change the outer tie rod ends.
    JT77Racin and Ford Freak like this.
  4. Rasit
    Rasit Member
    SE Pennsylvania
    They were the same, here’s the part numbers:
    Ford Freak likes this.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    As stated, just need the right outter tie rod ends.
  6. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    Thats what i have on my 69.5 all i had to do was use granada tie rod ends & hoses works great
  7. Ford Freak
    Thank you so much guys. It means a lot. I was freaking out ; thinking I’m screwed for the front end situation
  8. Ford Freak
    Now I’m going to pull apart the front clip. My phone is having issues uploading the Dana 44 pics in the rear
  9. bmcdaniel
    Yep, forgot about the hoses. And had to slightly reroute the hardlines, made a couple of brackets out of angled steel.
