Grant steering wheel problems
Discussion in 'Technical' started by mattwagner, Apr 17, 2014.
  1. mattwagner
    mattwagner Member
    Minnesota
    1976 Ford Maverick
    I installed a Grant 13.5" Challenger GT steering wheel in my Mav. I used the Grant 3249 installation kit with it. Now every time I turn to the right all my lights and radio shuts off. It is quite annoying and I am not sure what is causing this problem.
  2. 71gold
    sounds normal...for some of my installs...:bouncy:
  3. 14yearold
    14yearold Banned
    Virginia
    something is shorting out I had the same problem, might need a different adapter kit
    :huh:
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    13-1/2" is too small for a Maverick, plus it blocks your speedometer view.
  5. mattwagner
    mattwagner Member
    Minnesota
    1976 Ford Maverick
    I realized that after I installed it. But now I just want everything to work the way its suppose to
  6. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Do you have a justification for this? I've been intending to put in a 13 1/2" because I need the knee clearance. Also of note, I don't need the larger wheel size as a help for turning the car, I can already turn my manual steering parked with 2 fingers on the wheel. My arms have never been able to tell the difference between manual and power assisted steering.
    Blocking the instrument panel is NOT an issue for me also. :rofl: :thumbs2:
    I'm watching this thread, I was just about to order almost the exact same wheel and adapter.
  7. 14yearold
    14yearold Banned
    Virginia
    I believe it messes with the turn signals when you turn it
  8. Bryant
    unplug the horn button and tape off the horn wires and see if this stops it. i think there is supposed to be some clip in the button that needs to be cut to keep it from grounding out. if unplugging it works then read the grant instructions about the horn button.
