Hardware Lower Cross member tower - tower
Discussion in 'Technical' started by wrenchingfords, Nov 28, 2007.
  1. wrenchingfords
    wrenchingfords Member
    Canada, Calgary AB
    1974 Maverick 2 dr, 302 76 F250 supercab 460 2004 F250 6.0 turbo diesel 2005 Mustang GT 4.6 5sp stock
    Does anybody know the grade, length, diam., thread pitch of the two bolts to hold lower cross member on to a 74 maverick? U shaped bar that runs from under motor mount lh to rh side. When I bought the car cross member was in the trunk with no hardware!
  2. 71gold
    ...the belly bar... it takes a ...special bolt...countersunk head...
    you may be able to get a regular headed bolt to work.
    without looking i would say it is a ...9/16X2X14 :yup:
    if no answer by tomorrow i will pull one of mine and check it's size.
    ...Frank...:bouncy:
  3. Craig Selvey
    AMK Products sells the bolts if you want factory correct.
  4. wrenchingfords
    Canada, Calgary AB
    Thanks Frank I'll try a 9/16X2X14 standard head bolt to see if it fits.
    Seems that it is a pretty important part for a high power motor setup.
