has any one installed a PS pump drop bracket?
Discussion in 'Technical' started by blackpony, Jan 2, 2003.
  1. blackpony
    blackpony Member
    SC
    73 2 door
    got pics of how it goes in? cause i keep turning it around and just can't seem to make up my mind on which way it goes.....
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I just bought one for my Header swap - it looks like it replaces the bracket that mounts to the frame on the driver side that the cylinder mounts to. Don't think it can go on any other way than the correct way from the look of it ...
  3. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    Sorry i did not get back to you on the bracket.i still have it if you need one new from Headman.
  4. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    I had to drop mine another 1 1/2 inches cause of the 351w I think
    Once you have it bolted up have it welded in place because it will pull loose
    That and it shortens your left turns a little mine is a little more then yours would be because of the add drop
  5. Killercomet
    Dirtyburg, WV
    1973 comet
    The power steering rod? is it sopose to be bent? at the threads.mine is its not hurtining anything i just wanted to know.thanks
