header leak test
Discussion in 'Technical' started by koldham, Dec 24, 2012.
  1. koldham
    koldham Member
    Walnut Grove, Gerogia
    1973 Maverick
    so i had to modify a set of headmans to fit for my 302 swap. as i am a self taut welder, i am 100% sure there are leaks. how would i go about testing them to find where the leaks are. the engines isnt ready to run so i cant look for hot exhaust. any help is appreciated.
  2. Mavman72
    Plug the tube at one end and fill it with water or compressed air if you plug both ends.
  3. koldham
    koldham Member
    1973 Maverick
    How would you go about pluging the cylinderhead side tho? Ive tried wood but its not a watertight seal
  4. Joe Dirt
    look for potholes in your cleaned up weld
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    If you heated the flanges there's a good chance they warped. Bolt them up to the block with bolts finger tight and check all around for tight fit to the block.
    I just had to have the surfaces flattened on a NEW set of headers because the flanges were not flat.
  6. Dave B
    Make a steel plate to bolt on the head flange section, seal it up with some RTV, and fill it with water.
