Header Question?
Discussion in 'General Maverick/Comet' started by valleyracer, Sep 24, 2007.
  1. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    After doing the shock tower mods I want to upgrade! Is there any easyfit 1 3/4 headers for a 302?
    List any make and part# if possible!
    88300 Hedman 1 5/8 are on now
    Thanks
    Richard
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    There are guys here that have used Hooker 351w swap headers on 302s, and there is a big tube Crites header that has gotten high marks from a few here.
    I am sure they will chime in, but those are the two options.
    The Crites are easier to install from what I understand.
    Hooker 6208:
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK%2D6208HKR&N=700+0&autoview=sku
    Crites, PN unknown:
    http://www.critesrestoration.com/mustang.htm
    Edit: Crites is $160 cheaper!
    Just noticed that.
    The Hookers have gone up drastically.
    They weren't that high last I looked.
  3. valleyracer
    valleyracer Member
    Ottawa Canada
    Doug's has a step 1 3/4 to 2 1/8 listed on Jeg's #776-D669Y-R but I don't know if it would fit? Has anyone tried these?
  4. ratio411
    ratio411 Member
    Pensacola
    I believe those are Tri-Ys.
    So you have 2 primary pipes going into one 2.125" pipe, then those 2 pipes go into your collector.
    I tried a set of 1.5 into 1.75 into 2.5 Tri-Ys on my 72. They were for a Mustang.
    They didn't work on the driver's side.
    My clutch linkage hit them and the pitman arm of the steering crushed one of the secondary pipes.
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I'm curious, how big a motor do you need to run 1 3/4" headers? From what I've learned over the years, that would be huge for all but the biggest of small blocks.
