Headers= trouble
Discussion in 'Technical' started by Mr.Comet8795, May 31, 2008.
  1. Mr.Comet8795
    Mr.Comet8795 Member
    Easley S.C.
    1974 Comet/Mav. 342"
    I just dropped in my motor, and I have a set of 6901 hooker headers. For starters, they are hitting the steering arm, the bolts for the idler arm are hitting the passenger side tubes (I have manual steering), and the tubes also hit the strut towers...:mad::mad::mad: anybody have a suggestion???
  2. Mavman72
    B.F.H.Good luck.
  3. don graham
    Do you have power steering? If so you need the drop bracket. I have the 6901's in mine and they don't hit at all. I don't have p.s.
  4. rthomas771
    Turn the bolts around on the Idler arm bracket. On my Falcon I used a 3/8" spacer made from flat stock between the block and motor mounts to lift the engine in the bay. Be sure to use longer bolts if you go with a spacer
  5. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Do the headers bolt up?
    What motor mounts do you have?
    What side are you having trouble with the shock towers?
    These motor mounts will help you out alot because they allow you to move the motor around where it suits you...
    http://www.autoworksracing.com/Total_Control_Products_Motor_Mounts.htm
    I have had alot of experience with these and they are bad a$$!
    Call Matt and ask him if they fit the Mav. IIRC, the last time I talked to him, they do.
    If none if this works, let me know, and I will get you some headers that will work. (y)
    Jamie
  6. Decurion
    Decurion ....huh?
    Livonia, MI
    65 Comet, 65 Falcon, 01 Fosuc
    +1. I hated the Hookers in my car. They fit terrible.
  7. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    Same headers here, I had a couple of different problems, left side collector wouldn't clear the bracing that the trans mount bolts to. Also had a problem with the left side wanting to share the same space with part of the steering box, that wasnt too bad, but I had to relocate one of the primary tubes because of where the clutch cable goes through the scatter shield/motor plate.
    But scratch your head, have a cold one, and best of luck to you.:drink:
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I have a factory 302 car with p/s and C4 a/t.
    As stated, a drop down bracket is needed for
    p/s-but you say that yours is manual.
    Mine fit perfectly. I did make on dimple for the idler arm
    on the passenger side, nothing huge. All else fits perfectly.
    :hmmm: :huh:
  9. Halebopp
    Halebopp Member
    Ankeny Iowa
    Anyone got a part number for the drop down bracket? I am getting ready to buy headers I thought these headers were supposed to be a bolt on no problems, ???
  10. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    When I had 6901's in my Car ... they fit perfect ... and I even had a manual tranny z-bar to contend with ...
  11. scooper77515
    $33 From JEGS-- Hooker 10961 - Dynomax/Hedman/Hooker Header Accessory Brackets
  12. Halebopp
    Halebopp Member
    Ankeny Iowa
    ARe there subtle differnces in the alter model engine bays? to the guys who had little issues did you ahve v-8 to begin with? or were they six conversions? I ownder if there are subtle differneces in v-8 engine bays comapred to 6's
  13. Halebopp
    Halebopp Member
    Ankeny Iowa
    Thanks for the part numbers, boy I like working with Jegs they are helpful and fast
    never knew how much fun it is to get car stuff delivered to my door!!
