headlight/dimmer switch
Discussion in 'Technical' started by EFIMAV, Sep 1, 2013.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    It has been so long since driving at night that I can't remember these things! The headlight dimmer switch controls the dash light intensity. I replaced my old switch as it was a bit twitchy. However, if I turn the switch all the "up" shouldn't the dome light come on? Also, I asked about using LED lights in the dash for better illumination but failed to consider whether or not they are dimmable.
  2. rthomas771
    The dome light will come on if you turn the switch all the way. There's not much dimming LED's before they turn all the way off.
  3. simple man
    simple man Member
    Bunnell,Florida
    On mine, you turn the headlamp switch knob counter clockwise to turn on the dome light. It takes some effort! There is a spring loaded detent to overcome.. :)
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The headlight dimmer switch is on the floor. The dome light and instrument cluster light dimmer knob is on the headlight switch.
  5. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Thanks, my dome light works when I open the door but not when I turn the switch all the way to the left!!!! Brand new switch! I'll start digging.
