headlight trouble
Discussion in 'General Maverick/Comet' started by joe jones, Nov 2, 2014.
  1. joe jones
    joe jones Member
    louisiana
    maverick
    Headlights just quit working . Had not had a chance to check it out yet.i have a guess it mite be the headlight switch. Tryed the dimmer switch no high beams. What should I check first.
  2. Bryant
    most likely the head light switch.
    check the fuses first. use a test light to see where the power stops. if your fuses are good, check for power at the brights switch. if not power is there then its good odds that its the switch.
  3. joe jones
    joe jones Member
    louisiana
    maverick
    Thanks, that the route I was going to take.
  4. Krazy Comet
    Before going to all the trouble to try another headlight switch, would be a whole lot easier to see if there is power on the red/yellow wire that connects to dimmer switch(lights on)... If no power, then headlight switch is probably defective, if it has power you have other problems...
  5. hawkeye
    hawkeye Member
    perth, australia
    1971 comet gt
    I found a few weeks back that i had no headlights, so i swapped out all the old fuses as they were a bit rusty, still no lights so i started checking the wires working back from the headlights and found this fuse had blown
  6. 71gold
    "no high beams"
    if you have low beams it sounds to me like the dimmer switch. I had one once that would stick between high/low and I would have no lights.
  7. Craig Selvey
    That is not part of the factory wiring harness.
  8. Krazy Comet
    Someone has added that fuse rather than replace it with a fuse wire as orig, none of the fuses in the fuse panel are in the headlight circuit...
    Could be the dimmer as mentioned, but if either Hi or Lo is operating or only the Hi beam indicator is operating, problem isn't headlight sw...
  9. rthomas771
    Sounds like burned out headlights. Have you tried new headlight bulbs
