Headlights
Discussion in 'Technical' started by Bumlife, Feb 12, 2009.
  1. Bumlife
    Bumlife Member
    Twin Cities, Minnesota
    1976 Maverick, 4-door, automatic
    Both of my headlights went out a couple days ago, but the hi-beams still work. I was looking through a couple of other posts on here and they mention cleaning the grounds to fix headlight problems. I was wondering where they are (I'm guessing just right behind the headlights) and what I should clean them with.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The hi beam and low beams share the same ground. So if the hi beams work it is not the ground. Make sure the headlamps are good. Then check the dimmer switch.
  3. splatt
    splatt Member
    Claymont, Delaware
    1975 grabber, 53 Ford Mainline Gasser, 61 Porsche 356
    i had the same problem, was a bad dimmer switch. ten bucks.
  4. Bumlife
    Bumlife Member
    Thanks, I'll look into getting a new dimmer switch then. How do I replace it?
  5. maverick1970
    Missouri
    It is held in place by two screws and a wire connector. You will need to remove the drivers side kick panel in order to roll back the carpet far enough to access it.
  6. Bumlife
    Bumlife Member
    Well, I replaced it but I'm having the same problem still. Is there anything else it could be or did both my headlights just burn out at the same time?
  7. Acornridgeman
    Wisconsin
    Did you check the headlights first before the dimmer switch? It is not that unusual for both lights to go at the same time. It has happened to me. If you have a meter you can check continuity or just use a battery charger to check if they light up OK.
  8. Bumlife
    Bumlife Member
    I guess I should have. My dad was thinking that it would be pretty rare for both to go at the same time, so we thought it had to be something different. I'll check them out now though.
  9. Acornridgeman
    Wisconsin
    I blew both bulbs, low and high beam at the same time on a Ford F150 once and it was at night too. :coco:
    I had to drive home with only the fog lamps. Bought 2 new bulbs and it never happened again - no idea why.
  10. justin has a 74
    kentucky
    idk but my left directional isnt working... i changed the bulbs too
  11. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Don't forget about the firewall connector. That was a problem on mine.
  12. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    Years ago on 72 Comet Gt my headlights started to blink off & on one night and it was voltage regulator.
  13. Acornridgeman
    Wisconsin
    Yes, years ago it was not uncommon to see a car going down the road with the lights blinking. The headlamp switch has a self-resetting circuit breaker built into it. That is why it is so big and bulky compared to other switches. Your voltage regulator went wacko and that breaker kicked into action. :burnout:
  14. 71gold
    :yup:...had the same happen to me...:bouncy:
  15. 71gold
    had a dimmer switch to drop the low beams once... a replaced switch fixed it...:Handshake
