Headliner and window install questions
Discussion in 'General Maverick/Comet' started by scs, Dec 26, 2015.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I gave my Maverick a headliner for Christmas. It is glued onto the pinch weld all around and I need to finish it off. Here are my questions:
    1) Any suggestions for finishing the A&B Pillars?
    2) Do I need fiberglass filler under the rear sails?
    3) When I trim the xtra headliner for the front and rear glass installation, do I leave the headliner on both sides of the pinch weld (I did glue it on both sides)?
    4) Before installing the front and rear glass, is there anything I should do first (I have heard that some trim should go on first)?
    Thanks, this has gone fairly easy so far and I have never tried this before. The forum had some very helpful Tech Articles.
  2. Craig Selvey
    1. The A pillar has a plastic trim/button that completes that area. The B pillar simply gets a fold there.
    2. There are trim pieces that go at the bottom of the C pillar that also trim out the ends of the package tray.
    3. Leave the headliner on BOTH sides of the pinch weld.
    4. No trim goes on first....just install the glass first.
    gunslinger68 likes this.
  3. scs
    scs Member
    Prescott wisconsin
    Thanks Craig,
    Anyone have any pictures of the A, B and C pillar headliner finish? I'm not sure I have the plastic trim finish pieces for the A and C pillars.
  4. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
  5. 71gold
    I put sealer behind the clip studs before installing the trim clips.
  6. scs
    scs Member
    Prescott wisconsin
    Thanks, I think the above information answers all my questions except as follows:
    1) Does the attached picture show the A pillar clip referred to? If so, does it just pop out with plastic studs? I suspect I just fit a fold under it and reattach?
    2) I see no reason to put a fiberglass filler under the rear sail. Let me know if anyone feels strongly otherwise.
  7. Craig Selvey
    1) Yes....that is the clip. Take (2) small flat screwdrivers. Place them in the middle of the clip...one on each side. Gently pry both sides EQUALLY at the same time. Yes....Fold it under. Maybe somebody will post a picture of what it looked like originally. Mine has been redone or I would post it.
  8. William623
    William623 Member
    Orlando
    Be very careful when you do, they are easy to break...
    Craig Selvey likes this.
  9. scs
    scs Member
    Prescott wisconsin
    Impatient, I broke them both. Unfortunately, I did not see Craig's post before I tried, but I know where I can get 2 more. If not, just a fold doesn't look too bad.
  10. 71Mavrk
    71Mavrk Member
    Nevada
    SCS,
    Did you mark your screw holes for the coat/visor hooks, side window latches, overhead light and the visor center retainer? The can be a real PIA to find if you have not. My headliner guy had me put a screw in them before install. You can run your hands over it to find them. You then just cut them out with a razor blade.
    Micah
    71gold and William623 like this.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    SCS,
    Just looked at your original quetion.
    I had the jute type material at the rear sail panels. You can see the remnants in this picture:
    Micah
  12. scs
    scs Member
    Prescott wisconsin
    Thanks. I guess I should have put something under the sails, but I didn't. It is pulled pretty tight and I think I will be OK. Yes, I did put the screws in per the guidance in ford84stepside's post. I am happy with what I did considering it was a rookie attempt, but I would definitely do some things different. Lots of small details missing from any post I could find. I will post a summary of my lessons learned once the windows are in tomorrow.
  13. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I covered the pillars with the same headliner material.
    Minman1990 likes this.
  14. scs
    scs Member
    Prescott wisconsin
    I am in the middle of a window install with a local installer. We have some questions I am in urgent need of answers, so if someone knows windows, could you call me. It is 1:24PM central time and I would need help before 2PM. 715-603-5031
    Thanks,
    Steve
