headliner install
Discussion in 'Technical' started by MavMonster, Oct 5, 2004.
  1. MavMonster
    MavMonster Member
    Ames, Iowa
    72 Maverick
    Has anyone installed a headliner in a 2 door. I just ordered mine, I have NO idea how to take out the old one, let alone install the new. Any info would be great, thanks
  2. 71gold
    now would be a good time to put in new front and back glass seals. they pulled the glass when they put my liner in..frank...
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Keep the headliner bows numbered, you have to put them back in the same place they came outta. Yes the glass has to come out, if you have never taken glass out, or installed, I would find someone who has experience to guide you thru this the first time. Getting the headliner smooth and tight takes some work and just requires some good patience. One thing for sure, everybody who does anything started it out doing it for the first time at one time. ...........did I just say that? I think I got some Yogi Bera karma goin on lol
    Dan
  4. Acornridgeman
    Wisconsin
    This old thread will help you.
    http://www.mmb.maverick.to/showthread.php?t=1265&highlight=headliner+install
    I have done several Cougars and Mustangs and it is not that hard. It will greatly help to remove the glass. Best advice is GO SLOW AND KEEP YOUR HANDS CLEAN OF SEALER. If you do not want to remove the glass, I'd consider letting a trim shop do the work. Costs a lot, but no screw ups may be worth it in the long run.
  5. Earl Branham
    Lugoff, SC
    Jerry; coming to the All Ford Show at the plant on the 16th? Gonna be a good show. Drop me a line, and I will send you an application/entry blank. Later,
