Hello all, I'm new here and need HELP!
Discussion in 'New Members Forum' started by mulrowe, Jun 20, 2005.
  1. mulrowe
    mulrowe Member
    Los Angeles, CA
    Maverick Grabber
    Hello :wave:
    I would like to know if it is a hard thing to change a manual steering into power. I recently purchased a 71 maverick grabber with a straight 6 250cc automatic:clap: and it needs rebuilding. I drive the car now since it runs great but I'm a middle/novice machanic and would like to do some changes. my list of changes that I would like done is below:
    1) power steering
    2) air conditioning
    3) power windows
    4) disk breaks all around
    5) dual exhaust, probably headers
    6) electrical ignition like a MSD
    7) a little more power to the motor
    8) Bucket seats since the interior is trashed
    9) bigger wheels and gas shocks to raise the rear end.
    BUT the first is the power steering! is there a book I can get that will tell me if it is hard or not and what I would need?:hmmm: I have a list of some transferable parts but I need advice BIG TIME. is any of my items on the list not possible.
    Thanks for any assistance you can offer.
    Keith
  2. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    welcome
    :Welcome: Keith to the board sounds like you will have a real classy ride when you are done.Lots of info here and lots of good people to assist you on you're journey. Power steering can be done. lots of parts around for that conversion from steering boxes to cyls. etc. there are people here who have done that conversion .I am doing just the opposite...taking my power steering off. Again welcome...Jim(y)
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Welcome to the board.
    As stated, you can add power steering. Most people are removing it due
    to leaking and expensive parts needing replacement.
    As for dual exhaust. That is a little more difficult with a straight six.
    You can get a header for a 6 cyl. and there are tune up and speed
    parts available.
  4. don graham
    welcome to the board. good luck with your project.:Welcome:
  5. mulrowe
    mulrowe Member
    Los Angeles, CA
    Maverick Grabber
    Hello Jim
    Thanks for the welcome and info. I'm going to start buying my power steering parts so now the hunt begins. As for the leaks, isn't there some kind of boot kit available to help prevent that? I saw on ebay some thing to that extent. Anyways thanks again.
    Keith
  6. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Hey I just took all the power steering off of my 72 Mav. You can have them if you want, but I cut two of the hoses and the boot is torn. You can come pick them up (I'm south of you) or I can ship for a small handling fee plus shipping costs.
    -Erick
  7. rob's74cometgt
    rob's74cometgt Member
    Chilliwack, B.C., Canada
    74 Comet GT
    :Welcome: aboard. In regards to adding power steering it can be done but you'll need everything from the box, pump, pulleys to match, assist ram and will also need to change the centre link on the steering linkage (has the extra hole to hook up the ram). Personally, I had p/s but took it off, steers fine without it, plus it was a pain with the headers even with the drop down bracket for the ram. As for factory a/c, wow, that would be a big job to install as the factory a/c ones had the vents in the dash, unlike non-a/c ones. Addition of power windows and four wheel discs could be done but would require some :2cents: and ingenuity. As for any modifications to the exhaust, engine, ignition etc.you may want to consider swapping to a 302, you'll likely get more personal satisfaction for your dollar spent, then go with exhaust and ignition upgrades along with warming up the engine. Lots of decent seats are available and you may find a good used set to throw in. It all depends on how fancy or how technical you want to get but we'll be here when you decide on what you want to do and need assistance. Good luck.(y)
  8. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Keith, welcome to the board!!!
  9. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome
  10. Jean Doll
    Palmerton, PA
    Welcome to the board Keith!:Welcome:
  11. Mercurycruizers
    Venetia, PA
    :Welcome: to the board....
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
  13. mulrowe
    mulrowe Member
    Los Angeles, CA
    Maverick Grabber
    Thank you all for the warm welcome and advice. I'll be in touch! Definately
  14. Mavaholic
    Howdy and :Welcome:
  15. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Welcome...
