hi what parts can i use from a granada other then the brakes engine ? is the sterring box the same diff? belly pan? trans cross member ect thanks in advance
thanks for the info. does any one know off the the top of there heads what will fit /not fit i am sopose to go see him in an hour and i do not have the time to do the researchit is a 1977 granada
Front disc brakes swap, trans crossmember is the same, radiator should swap, engine and trannys swap, rear ends swap, look close, some came with 9" rears factory. Bucket seats and console will work, too. Not sure on the steering other than the power ram and pump being the same.
thanks too all looks like i am gonna start to build my 4 door yellow comet haha should be fun since i am a nebe with ford i will keep y'all posted
