Help! my carb is drowning!
Discussion in 'Technical' started by aquilaprime, Oct 1, 2005.
  1. aquilaprime
    aquilaprime Member
    Abilene, Texas
    1972 Grabber Wannabe
    Greetings, again.
    who knew that changing a fuel filter would cause me so much trouble today. The old one's threads sheared off when I tried to remove them - so i finally get them out, put the new filter on and cranked it just to find that my carb is overflowing with fuel: it wont quit flooding itself. I took the carb off, took the float chamber apart, found a small brass fitting lying in the bottom. I reseated it and noticed the float itself was sticking. so I freed it and tweaked it a little. I put it all back together, figuring I had figured it all out, but everytime I try to crank it, it just dumps fuel all over itself, drowning out. Any ideas? am I missing something?
    P.S. it's the stock carter 1 bbl on a 250 c.i. inline 6
  2. Jamie Miles
    Alto, GA
    I've had a few
    What engine? Sounds like your needle either fell out or is not seating correctly. Float could be sticking to.
  3. aquilaprime
    aquilaprime Member
    Abilene, Texas
    idiot me.....
    yeah, you mentioned the needle...um I'm just realizing that I think it was in the brass fitting that sheared-off the front of my carb with the old filter.:hmmm:
    thanks for the quick help!(y)
    okay...time to call the parts store.
    a.p. out
